Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda CRX / EF Civic (1988-1991)
Old 03-25-2011, 08:13 PM   #1
N'viouzEF9
1988 Honda Civic
nviouzef9 or sleeperef9
Send a message via Yahoo to N'viouzEF9
Icon3 car is running really ruff smells like gas to HELP!
my car ran fine then some wires that were really weak on my jumper harness broke finally so i ordered a new one well once i put it on i turned on the car and it idles really rough and smells like gas do u guys know what it can be i drIve a 88 ef dx mpfi wired with rywire n obd1 d15 could it be my battery or alternator? fyi car barley turned on in like a week any help thanks i need this fixed
team Envious 831
N'viouzEF9 is offline   Reply With Quote
Old 03-25-2011, 08:18 PM   #2
BiG ChOr!Zo
BiG ChOr!Zo's Avatar
iTrader Rating: (1)
Default Re: car is running really ruff smells like gas to HELP!
check the condition of your fuel injector seals and your fpr...i had a similar problem and swapped my fpr and i've been getting over 300 miles on a full tank and the gas smell went away...!!!
BiG ChOr!Zo'S Garage Sale Thread v.2<--click me
BiG ChOr!Zo is offline   Reply With Quote
Old 03-25-2011, 08:31 PM   #3
N'viouzEF9
1988 Honda Civic
thanks ill check that out but do u think that will happen out of no were?
team Envious 831
Old 03-25-2011, 08:37 PM   #4
BiG ChOr!Zo
iTrader Rating: (1)
it did to me but i also had a bad tps sensor (code 7) and it would run like ****...!!!
Old 03-25-2011, 08:39 PM   #5
N'viouzEF9
1988 Honda Civic
i had that code b4 then i change my throttle body n it went away ill see if i can get another fpr
team Envious 831
Old 03-25-2011, 10:24 PM   #6
N'viouzEF9
1988 Honda Civic
i also meant the exhaust fumes smell like gas really strong
team Envious 831
Old 03-27-2011, 01:40 PM   #7
Laserjock
Laserjock's Avatar
It is possible the harness you bought as a replacement have crossed wires if all you did was switch to the new one and the car ran fine before. It could be injector wire signals were crossed.
I would try another harness. Most jumper harness are not color coded so unless you know what you are doing, it would be a headache to trace the wires to the pinouts.
How bad is the broken wire in the old harness btw. It might be an easy fix. Post a pic
Laserjock is offline   Reply With Quote
1988, acura, car, change, crx, fuel, gas, honda, idle, idles, injectors, prelude, rough, smell, smells, tl
