timing belt on 93 civic
Old 03-25-2011, 03:35 PM
Cschues80's Avatar
Default timing belt on 93 civic
I'm having trouble getting the timing belt on a 93 civic. I was wondering if their is any tips or tricks. My dad and I both tried for about an hour with the engine out of the car and neither of us have never had a problem with a timing belt. Any suggestions would be appreciated.
Old 03-25-2011, 03:37 PM
The Grumpiest
grumblemarc's Avatar
Default Re: timing belt on 93 civic
Maybe try following this thread. It might help.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%5Bfaq%5D-complete-diy-how-timing-belt-water-pump-change-d16z6-lots-pics-649277/
Old 03-25-2011, 04:57 PM
Cschues80's Avatar
Good thread but my main problem is getting the belt on meaning that its way to tight but yet is.the same size as the one we took off. I saw that in the thread they said to put.the belt on the cam pully last but I've already.tried.that. still no luck
Old 03-25-2011, 04:59 PM
The Grumpiest
Silly question. Is the tensioner loose?
Old 03-25-2011, 06:08 PM
Cschues80's Avatar
Ya tentioner is loose. We tried having the belt off half way to give a little more slack and taking the crank pulley off but nothing seems to work
Old 03-25-2011, 06:31 PM
fonkernuckle's Avatar
how about pushing down on the tensioner and as you do so tighten it back up in the lowered position and install the beltl. Things would be easier if you leave the crank pulley off until you install the timing belt or do you mean the crank gear.
Old 03-25-2011, 06:45 PM
Cschues80's Avatar
We did push the tensioner down and the crank gear. Sorry. The problem is when we push the tentioner down we can't put the bolt back in.
Old 03-25-2011, 07:42 PM
leave the bolt in loosen the tensioner(you can use a screwdriver on the spring end of tensioner and push down)once down tighten the tensioner in the lowered position.
There is no need to remove the tensioer bolt for the tensioner to move
Old 03-26-2011, 04:35 AM
Cschues80's Avatar
Ok that sounds like it would be a.little easier. thanks
.Ry
11
10-08-2007 03:59 PM
omgwtfbbqcrx
02-16-2006 09:38 PM
Crosbydp
01-03-2006 07:27 PM
1SlowSi
02-06-2005 04:39 PM
Quick Reply: timing belt on 93 civic
