Cost to benefit: oversize valves?
Old 03-22-2011, 05:38 PM
bigsnorlax's Avatar
Default Cost to benefit: oversize valves?
Mild build up of a f22a. 86mm bore by 95mm stroke, bisi stage 2 cams, and 12.1 pistons and more, those are just the basics.
Now anyways, bisi just added new valves you can buy on their site. +2mm intake and +1mm exhaust. That seems TOO big for a street motor but other than that the only other option seems to be +.5mm valves. Does a motor like this really NEED bigger valves? Or would i just be throwin money away for nothing? I havent really seen a lot of people mention going bigger on here, and some even swear by the stock valves with just a valve job.
Any opinions welcomed, thanks!
Old 03-22-2011, 06:21 PM
unusual71's Avatar
Default Re: Cost to benefit: oversize valves?
how high are you planning on revving? you might benifit from a larger valve if your going to rev to 9k and only need power up top.
for a street engine...well unless you work it into the design the gains will be almost nil.
Now say if you had plans on maybe adding a bit of juice down the road or something then its a different story
Old 03-22-2011, 07:23 PM
bigsnorlax's Avatar
My builder said i could safely go to 9k... but i will mostly keep it to a 7.5k - 8k max. With its long stock stroke im really hoping that it will be more of a very streetable torque monster making good power in a usable RPM for cruising but also with the pistons and cam make some good top end.
Guess they arent really worth it for my application. I figure if i end up re-sleeving and boring out to 89mm and go for broke with that 100mm stroker crank i'd benefit more.
Old 03-22-2011, 08:11 PM
Combustion Contraption's Avatar
When Honda designed the K24, (86x99), they went with 36mm INT valves. Just sayin.
Old 03-22-2011, 08:27 PM
2k.civic.si's Avatar
why dont you ask bisi
he is definetly the master of the f series.
Bond
07-22-2007 02:12 PM
^jefs0ng
12-09-2003 06:48 PM
miksew
08-26-2003 11:16 PM
Riptide101
04-10-2003 01:23 PM
Smoothy
09-23-2001 05:38 PM
Quick Reply: Cost to benefit: oversize valves?
