Old 03-20-2011, 11:25 PM   #1
killerkali420
Default hay 91 accord idles up and down
i have a 91 honda accord ex that idles up and down butwhen i take the # 21 vaccume line off it stops. can anyone tell me whats going on with my car
killerkali420 is offline   Reply With Quote
Old 03-21-2011, 04:21 AM   #2
nus_dogg
1994 Honda Accord
nus_dogg's Avatar
Default Re: hay 91 accord idles up and down
When does it do it? When it's cold or running hot at nomral temp?
1994 Honda Accord EX - JDM H22A
- 204whp/157wtq
Originally Posted by toycar View Post
Breaking the bank, maybe. Feeling like a boss, likely.
nus_dogg is offline   Reply With Quote
Old 03-21-2011, 02:54 PM   #3
killerkali420
all the time dosent matter on the temp
Old 03-21-2011, 08:24 PM   #4
matrix9_11
tighten the idle air valvle scew up i had two different ones do the same thing and another one was the intake gasket it sounds the same
matrix9_11 is offline   Reply With Quote
Old 03-22-2011, 07:18 AM   #5
MC Slide Hammer
apparently, idle surging happens with any vacuum leak.
i once had to unbolt my egr valve and had to leave it on loose; i started and ran the car - it was surging.
it just so happens that the fast idle thermal valve tends to be the most common (naturally occurring, when cold) source of a leak on hondas, though that may not be the case here.
try to find out what the source of your vacuum leak is -what is vacumm line 21 hooked up to?- and fix it.
MC Slide Hammer is offline   Reply With Quote
90, 91, 94, accord, cold, del, honda, hot, idel, idle, idles, idling, make, ran, revs, sol, wagon
