f22b1 head studs????
Old 03-17-2011, 09:17 PM
team_lunatics's Avatar
Default f22b1 head studs????
hi everyone,
i have a f22b1 motor and was wondering if anyone knew if arp makes a head studs kit for them? i looked on arp sites and they dont have one on there. i asked other people and they say the h23 head studs will fit. can anyone confirm this for me. thanks.
Old 03-17-2011, 10:30 PM
InvaderTrax's Avatar
Default Re: f22b1 head studs????
Originally Posted by team_lunatics
hi everyone,
I'm 100% sure F23A1 and H23A1 head bolts are the same, so assuming F23A1 and F22B1 head bolts are the same...
Old 03-17-2011, 11:10 PM
91accordexr33's Avatar
Yes, use ARP-208-4307 H23 head stud kit. It will fit F22 and H23. I used the same studs when I ran a B1 head
Old 09-27-2011, 07:54 AM
jtwoj1's Avatar
Are one of the studs in this kit (ARP-208-4307) longer? I ask because the picture shows all the studs the same langth. The factroy bolts I pulled from my F22b1 had one bolt about 1-2 in. longer then the rest. I just don't want to make a second misstake on buying performance parts.
Old 09-27-2011, 08:31 AM
ncoutlaw's Avatar
.there the same as the f23a4. I have an set I cant use ne more. Did an h head swap and they dont fit
Old 09-27-2011, 08:54 AM
hondamark35's Avatar
yes, the kit specified for the H23 has one stud longer than the rest. it should work with any single cam (F-series) head on any H-series or F-series block.
Old 09-27-2011, 10:37 AM
jtwoj1's Avatar
Thanks for the fast responce. I also ask the same question from ARP and there responce was
There are nine studs in that kit that measure 7.250". There is one thatmeasures 8.500" overall. Regards,Zac KimballAutomotive Racing Products(805) 339-2200 ext. 206
Again thank you order made
Old 11-26-2011, 11:54 AM
Repsolo's Avatar
I know this thread is a little old, but I ordered the H23 Head studs also, Where does the longer head stud go?
Old 11-26-2011, 05:26 PM
the middle stud on the back (intake side) of the motor. you'll notice that the oil feed for the head comes up there and the seat for the nut and washer is higher there than the other stud locations on the head. it's very obvious if you get it wrong.
j3wman
11-04-2009 03:34 AM
H23civichatch
03-14-2009 08:29 PM
hondamark35
10-31-2008 05:05 AM
BOMBCRU
02-07-2008 10:15 AM
noslude93
02-19-2003 08:57 PM
Quick Reply: f22b1 head studs????
