Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Acura Integra Type-R
Old 03-16-2011, 07:05 PM   #1
BlueIntegraBoy
1998 Acura Integra
BlueIntegraBoy's Avatar
iTrader Rating: (3)
Default Car dies while driving (sputters then dies)
Some of you may know, I am no where near my R. I left the R with my GF and her family to store and run it once in a while when I am in school. The following is what they described to me:
They took the car out for a drive and they said it started up fine. At one point during the drive at a stoplight, they noticed the tach needle bouncing up and down to redline (engine did not follow), but the engine started sputtering and then died. I guess they tried starting the car again, it ran for a little bit but sputtered and died again.
This is all the info I have from them. Any ideas?
インテグラ タイプR 98-0425
07 Pilot EX-L w/Navi & 4x4
BlueIntegraBoy is offline   Reply With Quote
Old 03-17-2011, 08:02 AM   #2
ekswapdude
Default Re: Car dies while driving (sputters then dies)
its your fuel filter is what is seems to me. im on my 6th and 7th honda and the very few occasions this has happened to me it was always the fuel filter. once the car dies and the fuel is not being pushed through, the gunk has time to settle allowing more fuel to pass. once the car starts running again... the fuel brings the gunk right back to filter, starving your motor causing it to die...
ekswapdude is offline   Reply With Quote
Old 03-17-2011, 08:07 AM   #3
BlueIntegraBoy
1998 Acura Integra
iTrader Rating: (3)
Yeah, it might be it since the car has just been sitting for over a month without a start.
インテグラ タイプR 98-0425
Old 03-17-2011, 08:24 AM   #4
guanacoracing
2004 Acura TSX
Fuel filter issue sounds about right. I have to say, though, that we stored our R early December and did not start it until sometime in late January (over a month later) and it started right up.
Nick, keeps up posted on what you or your GF may be able to find out.
guanacoracing is offline   Reply With Quote
Old 03-17-2011, 08:37 AM   #5
BlueIntegraBoy
1998 Acura Integra
iTrader Rating: (3)
I'm going to order one from Del Ray. It just sucks that I'm 6000+ miles away and I can't do anything about it.
I'm also a little worried about the tach bouncing problem. Electrical problems suck.
インテグラ タイプR 98-0425
Old 03-17-2011, 09:52 AM   #6
Ultraspeed DC2
Ultraspeed DC2's Avatar
Send a message via AIM to Ultraspeed DC2
Take your distributor cap off and dust cover, clean off the contacts and you also might have to compress the connectors so they're tight if they are loose.
98-0729 JH4DC231FTHEIVES http://youtube.com/watch?v=und0_f0DUn0
FS/WTB Vouches: Henryx33, eluam, Comp97GSR, R-gonaut, lengualoco21, RTW DC2R, PrinceAli132, Redcoupe, neof69, doespike, Dave B
Ultraspeed DC2 is offline   Reply With Quote
Old 03-18-2011, 06:01 PM   #7
jawls
jawls's Avatar
I'm agreeing with everyone on the filter. That would definately make it sputter and die. And the idle problem could possibly be your IAC. But I wouldn't imagine your tach going up to redline. Or wait, did you say that the engine didn't rev up when the tach went up? Sorry, I was kind of confused. But if the motor revs up as well...I would check your IAC voltage. It should have a 5 volt reference, with the key in the on position. And it is possible you have a vacuum leak. A vacuum leak will make your idle rough and fluctuate. Again, this is if your motor rpms increase. Let me know. Good luck man.
jawls is offline   Reply With Quote
Old 03-18-2011, 06:14 PM   #8
BlueIntegraBoy
1998 Acura Integra
iTrader Rating: (3)
This is correct
インテグラ タイプR 98-0425
Old 03-18-2011, 06:21 PM   #9
jawls
jawls's Avatar
Possible short to power somewhere in the electrical circuit? Cause the tach to fluctuate. I'm not sure man. I'll ask a few friends and see what they think. Find out how often it does it, and if they can pin point exactly when it is doing it. ex. idle, high idle, cruising etc.
Old 03-18-2011, 06:54 PM   #10
BlueIntegraBoy
1998 Acura Integra
iTrader Rating: (3)
I will fix the clogged filter and work from there. Like I said, I'm far away from the R.
インテグラ タイプR 98-0425
Old 04-04-2011, 09:03 AM   #11
guanacoracing
2004 Acura TSX
Hey Nick: Did you or your GF figure out what was wrong?
Old 04-04-2011, 09:43 AM   #12
AllShowNoGo727
iTrader Rating: (1)
v8killerb18
I bet its something to do with the distributor.
Phearable.net Tuning FTW! Race-Spec Trusted and Proven Motorsport Wiring
AllShowNoGo727 is offline   Reply With Quote
Old 04-04-2011, 11:59 AM   #13
BlueIntegraBoy
1998 Acura Integra
iTrader Rating: (3)
I think it's the conversion harness that I am using. When I first picked up the R, it came with an OBD2A-OBD1 harness that looked like crap. My GF's dad's friend looked at the car and said whenever he jiggled the harness, the engine started to sputter. Maybe the pins weren't connected well. I ordered a new conversion harness from Phearable, but it hasn't been installed yet.
As for the dizzy comment.. the dizzy is new.
インテグラ タイプR 98-0425
Old 04-05-2011, 10:27 AM   #14
AllShowNoGo727
iTrader Rating: (1)
v8killerb18
^ you say the dizzy is new as in an ebay/advanced/autzone new? swap a friends oem dizzy it does not hurt to try it out.
Old 04-05-2011, 12:57 PM   #15
BlueIntegraBoy
1998 Acura Integra
iTrader Rating: (3)
DizzyKing
インテグラ タイプR 98-0425
Old 04-06-2011, 06:28 AM   #16
EFsSuck
EFsSuck's Avatar
bump!
same thing is happening with my beater right now but I don't see how a bad fuel filter is going to cause a tach to bounce around? that is an electrical/spark kinda thing...
EFsSuck is offline   Reply With Quote
Old 04-06-2011, 07:50 AM   #17
get RIGHT
get RIGHT's Avatar
I had this same symptom about a year ago and it turned out to be bad spark plugs. I dont see it as a fuel filter issue at all.
SCCA solo II DSP #77
SCCA TimeTrials TT2 #77
SCCA RallyX SF #77
get RIGHT is offline   Reply With Quote
Old 04-06-2011, 07:54 AM   #18
Tyrant_007
Tyrant_007's Avatar
iTrader Rating: (1)
I had a very similar issue with an old CRX SI I had. I installed a new distributor (Distributor King), and that fixed my problem. I was told the bearings went out in it. All I know is it fixed it. They make good distributors though, so i wouldn't think it would go bad that fast. Hopefully it's just your harness that you bought.
2001 Integra Type-R NBP #201
Integra Type R Registry - Add your caR
Tyrant_007 is offline   Reply With Quote
Old 04-06-2011, 07:58 AM   #19
JEBirdman
That's a good suggestion and I agree that it prob wouldn't go bad so fast but there is a chance you just got a bad distributor. It happens sometimes... used 2004 2008 volkswagen gti r32 review in portland or
JEBirdman is offline   Reply With Quote
Old 04-06-2011, 08:17 AM   #20
Dave_B
Dave_B's Avatar
I hate distributor king dizzy's. Their CS and support sucks.
But first, try with another known good dizzy to see if that solves the problem.
The tach bouncing like that tells me it's electrical and not fuel starvation from a fuel filter. Most likely an EFI main, or dizzy.
<--- just bought a car, and EFI main harness was the culprit. Previous owner(s) installed a make shift kill switch and the connection was poor.
PY Track car build http://www.honda-tech.com/zerothread?id=1373697
FS: ITR and B-series parts: http://www.hondamarketplace.com/show...php?p=47100149
Dave_B is offline   Reply With Quote
Old 04-06-2011, 10:56 AM   #21
BlueIntegraBoy
1998 Acura Integra
iTrader Rating: (3)
Thanks for the suggestion guys. It's going to be a slow process since I am not physically at home to check out the R. But any updates and I will post here.
If it is the dizzy, I might just have to hold off on buying another one, but I think DizzyKing has a warranty.
Also, when my GF and her dad was checking out the car last week, they said it started and ran fine. Problem might be intermittent or a one time thing.
インテグラ タイプR 98-0425
Old 04-10-2011, 06:01 AM   #22
creelgriffin
I also am having an Acura engine problem but firstly my biggest issue is to know how to post or start a new post so I can get some inputs. Can you or anyone help me with instructions on how I can post a new topic for discussion about my Acura engine problem? Thank you. [Smile]
creelgriffin is offline   Reply With Quote
Old 04-11-2011, 12:08 PM   #23
GUILOTINE
Kill Gil
1997 Acura Integra
GUILOTINE's Avatar
http://www.facebook.com/profile.php?id=537873220#!/profile.php?id=537873220
Send a message via AIM to GUILOTINE
Ignition issue is my guess
GUILOTINE is offline   Reply With Quote
Old 04-15-2011, 10:20 PM   #24
spcrxracer
spcrxracer's Avatar
iTrader Rating: (1)
Send a message via AIM to spcrxracer
I've had this problem once before. Turns out, the adjustable fuel pressure regulator I installed was internally defective (and I didn't know it). I swapped it back to the stock unit and car ran like a champ
Start with the fuel regulator and filter. Then move to ignition-related problems.
"A car in a garage is safe -- but that is not what cars are built for"
Those who buy Quality cry only once.
CRX
spcrxracer is offline   Reply With Quote
Old 04-16-2011, 09:17 AM   #25
TOO MUCH TORQUE
TOO MUCH TORQUE's Avatar
a bouncing tachometer is the ignitor failing. good luck
TOO MUCH TORQUE is offline   Reply With Quote
alternator, car, cruising, dies, driving, engine, jumping, motorcycle, quits, running, sputtering, sputters, stalls, starts, stops
