Go Back   Honda-Tech > Community Forums > General Discussion and Debate > Electronics, Gaming & Photography
Old 03-16-2011, 06:08 AM   #1
loki2323
loki2323's Avatar
Default Data recovery help- external hard drive showing up as unallocated
I have a 2tb WD Essentials drive that had problems with a loose usb connection. I think the drive got messed up some how with it connecting and disconnecting. So I purchased an new enclosure to solve the issue and now the drive shows up in disk management as "unallocated".
Last night I tried a program called active partition recovery and with that I was able to actually see all folders I need and all the sub folders. Problem is that I don't think it fixed anything.
So....does anyone have any suggestions on how I can recover the data on this drive? I'm assuming that once I pull it off I can format the drive and that should get the drive up and running again?
I'm going to try test drive and getdataback ntfs tonight and see what I can come up with.
loki2323 is offline   Reply With Quote
Old 03-17-2011, 05:55 AM   #2
loki2323
loki2323's Avatar
Default Re: Data recovery help- external hard drive showing up as unallocated
Solved
Well if anyone runs into a similar issue, I used testdisk and I was able to get the drive to show up again.
Now in the process of backing up 1.5 tb....which windows estimates taking 12 hours
Old 05-19-2011, 12:34 PM   #3
phengnhou
phengnhou's Avatar
Send a message via AIM to phengnhou
Hey I'm having the same problem. How did you go about getting all the data back? I download testdisk, but was unsure what i need to do.
phengnhou is offline   Reply With Quote
data, disk, drive, drives, external, hard, ntfs, recover, show, showing, shows, unallocated, utility, windows, xp
