Old 03-14-2011, 03:20 PM   #1
karen7
Default need f22b1 vtec wiring help 96 accord
I know there is info everywhere, but I cant seeme to find all the info I'm looking for. I am finding all h22 but thats not what i need.
I bought a 96 accord LX Auto(non vtec) with an f22b1 vtec motor. The vtec is NOT wired or working. (The car might be in limp mode, not sure. This is my first honda.)
Anyway, I bought the P0H ECU. I had to replace all the wiring under the dash because it was burnt and melted. I did NOT get the engine wiring harness.
When I get up to vtec kick in point it doesnt shift, I have to let off for it to shift.
I have read that I need to wire the vtec solenoid and oil pressure switch. My motor does NOT have the oil pressure switch, there is a bolt in it. I checked the junkyard and they are the same. I am not able to buy the switch at the parts store.
Does the oil pressure switch have to be wired? Where can I buy one? Does anyone have the ecu pinout with wire colors for the 96/97 obd2? Help me please. I'm getting a vtec malfunction code with the CEL and I need to get the car inspected this week and the CEL can't be on. thanks
karen7 is offline   Reply With Quote
Old 03-21-2011, 05:32 PM   #2
karen7
Default Re: need f22b1 vtec wiring help 96 accord
bump. Still needing this info. Thanks
Old 04-23-2011, 06:56 PM   #3
eugenrosado
i am having the exact problem and am nearly there with the answers but still dont have the pin up yet. i was told to google 2.2 v-tec obd2 pinout and there you should find what you looking for im still stuck if you have any luck please help me thanks
eugenrosado is offline   Reply With Quote
Old 04-24-2011, 05:33 AM   #4
poorman212
Search...I've seen this discussed here several times....heck it might actually be in the FAQ.
http://www.honda-tech.com/showthread.php?t=2706310
66 Chevelle...89 LX auto...89 LXI 5 Speed
...95 EX auto...07 Pilot 2wd
87 LX 5 Spd (sold )...88 LXI Auto (soon to be sold)
poorman212 is offline   Reply With Quote
Old 04-24-2011, 01:51 PM   #5
GhostAccord
1996 Honda Accord
GhostAccord's Avatar
lol nice link^^^
The OBD2 F22B1 VTEC does not have a pressure switch. It only has the VTEC solenoid, that is why there is a bolt where the PSW usually is. The VTEC solenoid is wired to Pin A8 of the VTEC ECU. The other wire of the solenoid goes to chassis ground.
OBD2 Connectors, view from wire side
Wire colours around the VTEC pin;
A1 is YEL
A2 is BLU
A3 is RED
A4 is BRN
A5 is ORG/BLU or ORG/BLK
A6 is ORG/BLK
A7 is empty
A8 is GRN/YEL VTEC Solenoid............
A9 is BRN/BLK
However if you are adding VTEC to a non VTEC Accord. I don't think the GRN/YEL VTEC wire will be in the ECU wire harness.... Unless you replaced it.
GhostAccord is offline   Reply With Quote
Old 06-06-2011, 11:57 PM   #6
thomas's96vetec
hey i have all ready did this swap, i was able to buy my motor with harnes it all bolted striat up with my f22b2 auto trans, the harnes pluged up just fine and i had found the right ecu i just had to run a wire from the ecu to my harnes for the vetec and im proud to say iv had it up to 130mph
thomas's96vetec is offline   Reply With Quote
Old 02-26-2013, 04:11 PM   #7
brandon9686
Originally Posted by GhostAccord View Post
lol nice link^^^
A1 is YEL
A2 is BLU
A3 is RED
A4 is BRN
A6 is ORG/BLK
A7 is empty
A9 is BRN/BLK
hi i have a 97 accord ex and there is a male connector on the oil pressure senesor (i think that is what it is called) that screws onto the the vtec solenoid but i can not find the wiring to plug into it. the plug that is missing is green. my car is putting out p1253 engine code. wanted to know if anyone knows where the wires start from so i can run new wires and if that is the reason for the engine code.
brandon9686 is offline   Reply With Quote
1993, 1996, 91, 92, 96, accord, ecu, f22b1, h22a, honda, locate, pinout, vtec, wire, wiring
Similar Threads
The Official "Why VTEC doesn't Engage" Thread prelittlelude Honda Prelude 135 10-10-2013 06:38 PM
02 accord f23a4 to h23a vtec wireing help please acaliguy Honda Accord (1990 - 2002) 6 02-04-2013 08:53 PM
93 accord H22A p13 cel 22 Saurik Honda Accord (1990 - 2002) 1 01-08-2013 01:26 AM
OIL PRESSURE SWITCH PIN NUMBER????? Crxh22ajdm Honda Prelude 4 01-02-2013 10:51 PM
96 accord head swap non vtec to vtec smacconnell Honda Accord (1990 - 2002) 22 09-28-2012 05:31 AM
