Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda CRX / EF Civic (1988-1991)
Old 03-09-2011, 01:10 PM   #1
slob20ef
Send a message via AIM to slob20ef
Default 89 crx bouncing idle help please
I swapped a d15b into my 89 crx dx, converted to obd1. Im having problems with the car bouncing or surging idle, from 1200-1600 rpm. I took the FITV apart, cleaned and tighten. I also cleaned IACV, then replaced with another. Bleed coolant system a million times now. I plug the hole inside the TB and no difference, i unhook the IACV and still no difference, now it will idle at 800 steady rpm fine, you give it a very little throttle and it starts surging, all vacuum lines are fine, checked with carb and choke cleaner, same with Tb and Im gaskets. I hardwired IACV to ecu, A9, blk/blu wire, and grounded the yell/blk. Ive fixed several cars with this problem before but this has got me. Seems like the IACV wiring is not right, but its not hard wiring a 2 wire plug.. any ideas?
89 crx dx build thread
http://www.honda-tech.com/showthread.php?t=2892292
slob20ef is offline   Reply With Quote
89, 90, bouncing, bouncy, civic, crx, d15b, hardwire, honda, iacv, idle, jdm, problems, rpm, surge
