Crankshaft bolt removal?
Old 03-09-2011, 07:27 AM
romikbal's Avatar
Default Crankshaft bolt removal?
Hey folks
I have a 96 Accord Aerodeck Auto which needs the water pump replaced.
Have managed to get as far as trying to remove the flywheel but am unable to budge the bolt!
We have a tool to hold the flywheel and have tried using large bars on the end of the socket but can't move the bolt. Any ideas?
We have been trying to turn the bolt Anti clockwise.... is this correct?
thanks
Old 03-09-2011, 09:03 AM
Jmb106jr's Avatar
Default Re: Crankshaft bolt removal?
Counter clockwise is the direction to remove bolt, you are correct. I have heard of people have luck removing bolt by heating it up w/ propane torch,ect, then hitting it w/ a impact gun. Good luck to you.
Old 03-09-2011, 09:33 AM
InvaderTrax's Avatar
Still haven't had issues using my big impact. You can always search the starter trick
Old 03-09-2011, 09:44 AM
djkurious's Avatar
Try step 10: https://honda-tech.com/forums/honda-accord-1990-2002-2/how-replace-timing-belt-timing-balancer-belt-water-pump-f22b1-1908944/
Old 03-09-2011, 10:42 AM
ek9civichb's Avatar
x2 step 10
Old 03-09-2011, 11:01 AM
nus_dogg's Avatar
^^ x3!
And my nice impact gun has not failed on me yet when it comes to a Honda Crank Pulley bolt(Knock on Wood).
Old 03-09-2011, 11:43 AM
djkurious's Avatar
I definitely would not use this.
Old 03-09-2011, 11:51 AM
MoguMagic's Avatar
Screw driver in the flywheel but you seem to have that covered, Large as you can breaker bar with an extension held up with jackstand/wood/whatever to not bend the extension as you turn it. Tighten it then try untighten. Always works after few min. Bounce, Jump. Hang on the bar listening to some sort of dance music. Just get it down and watch out if your under it when it goes.
Old 03-09-2011, 12:10 PM
romikbal's Avatar
Thanks everyone!
Will persevere! Great Job with the write up Touring Accord!
Old 03-10-2011, 05:32 AM
H-T Order of Merit
TouringAccord's Avatar
Thanks
Old 03-10-2011, 05:33 PM
MM Gruppe B
MAD_MIKE's Avatar
On the F and H engines this will tighten the bolt, not loosen it.
I used a jack stand under the extension as my fat ~230lb *** tried breaking the bolt free by diving board bouncing on it.
beansandrice
06-27-2011 02:01 PM
Safebet
12-05-2010 12:04 PM
clayne
10-19-2006 10:25 PM
all motor b20b
02-22-2005 01:05 AM
mongoliandonuts
17
12-15-2003 01:44 PM
Quick Reply: Crankshaft bolt removal?
