Old 03-07-2011, 11:40 AM   #1
97civicgirl
97civicgirl's Avatar
Default Removing stripped frozen bolt on exhaust pipe. Please help!
Hi all,
I am knee deep in dropping my tranny to replace my rear main seal on my 97 civic and have hit a snag with a rusted, stripped, frozen bolt on the exhaust pipe nearest to front of car.
I have tried soaking in PB Blast overnight, taking a propane torch to it, and hammering a smaller sized socket onto in my attempts to break it. Nothing is working. Angle grinder won't fit to cut it off that way.
Any suggestions???
Thanks!!
97civicgirl is offline   Reply With Quote
Old 03-07-2011, 11:49 AM   #2
pityocamptes
pityocamptes's Avatar
Default Re: Removing stripped frozen bolt on exhaust pipe. Please help!
The one bolting to the exhaust mani down pipe or where the cat connects?
pityocamptes is offline   Reply With Quote
Old 03-07-2011, 11:53 AM   #3
pityocamptes
You could always drill it out and twist the head or nut off.
Old 03-07-2011, 12:01 PM   #4
Linked
1994 Honda Civic
Linked's Avatar
linkedscorpion
lift the car higher, drop the exhaust by removing it off the hangers, and take the angle grinder to it, hammer out the rest
if its that bad to the point where a torch wont get it, its not gonna unscrew
2010 cadillac cts-v / 556 bhp / $62,020
only an idiot would buy a $62,000 cadillac
Originally Posted by 92lxsleeper View Post
it takes an even bigger idiot to put the $62,000 price tag on it
Linked is offline   Reply With Quote
Old 03-07-2011, 12:05 PM   #5
pityocamptes
...or split the nut sides with a really sharp cold chisel...
Old 03-07-2011, 12:07 PM   #6
94EG8
Honda-Tech gave me this lousy title
94EG8's Avatar
Bolt/nut extractor usually works pretty decent. Or remove the entire setup like someone else said it and cut it out, or cut the stud out with a torch or stick welder.
"Bacon tendercrisp chicken, the most powerful sandwich in its class."
Per ardua ad astra
My F/S thread -> http://hondamarketplace.com/showthread.php?t=2900962
Originally Posted by Knightsport View Post
Hello,
This is Knightsport, from the internet. I will be out of the internet from June 2 and returning on June 11th. In my absence I suggest you pray as there can be only one Knightsport from the internet.
Thank you and God Bless,
-Knightsport
94EG8 is offline   Reply With Quote
Old 03-07-2011, 12:32 PM   #7
97civicgirl
Thanks for the quick replies!! It is the last of the 3 bolts that attaches the pipe to the cat.
OK... will try the cold chisel now, as I don't want to have to remove the manifold.
Thanks!!
Old 03-07-2011, 12:49 PM   #8
97civicgirl
Chisel did not work either.
Old 03-07-2011, 01:12 PM   #9
pityocamptes
Do you have or know anyone with a Dremel tool? I have used the cut off wheels for Dremels when space was tight. The other option is taking a hack saw blade, and if room is tight take the blade from the handle, wear gloves and just use the blade to cut through the bolt.
Old 03-07-2011, 01:18 PM   #10
pityocamptes
Ok, I know which area you are talking about, and it is a bitch. Can you drill the head or nut out? All you have to do is drill most of it out and you should be able to twist that end off pretty easy with a wrench on one side and a socket/rachet on the other.
Old 03-07-2011, 01:54 PM   #11
97civicgirl
This is the bolt (assuming I figured out how to post pics correctly).
Old 03-07-2011, 01:59 PM   #12
delsizzle1
2009 Nissan 370Z
My Garage
delsizzle1's Avatar
use a dremel.. the wheels cut pretty good n they are small enough to get in there like a previous person had said as well.... be sure to wear sometype of goggles while performing this tho... metal shards in the eye are ****in killer...
delsizzle1 is offline   Reply With Quote
Old 03-07-2011, 04:24 PM   #13
97civicgirl
My friend has a dremel... we will try that in the morning. Hope it works!
Old 03-07-2011, 05:05 PM   #14
97civicdx
97civicdx's Avatar
Cant you just torch it off. Thats what most muffler shops do, LOL
97civicdx is offline   Reply With Quote
Old 03-07-2011, 05:23 PM   #15
fonkernuckle
fonkernuckle's Avatar
iTrader Rating: (4)
I suggest making sacrifice to Apollo, and then after that, remove the exhaust and use a cut-off tool or grinder
fonkernuckle is offline   Reply With Quote
Old 03-08-2011, 10:47 AM   #16
97civicgirl
It's off!! Yay!! We used the dremel and cut through the bolt, then used an air chisel to break it loose. Geez... we have spent more time with this one bolt than we have doing everything else so far in the entire project.
Now... it's time to place jack under tranny and remove the last support bolts... :D
Thanks everyone for your help!
Old 03-08-2011, 11:47 AM   #17
pityocamptes
Nice.
For breaking news, financials, weapons, military manuals, outdoor, survival and when TSHTF come to:
https://www.gunsgrubandgold.com Easy to sign up, and its free!!
air, bolt, car, chisel, civic, cut, exhaust, frame, frozen, honda, pipe, remove, rusted, stripped, tool
