Go Back   Honda-Tech > Community Forums > General Discussion and Debate
Old 03-05-2011, 01:35 PM   #1
iheartjayDem
iheartjayDem's Avatar
Send a message via AIM to iheartjayDem
Default denatured alcohol to pass CA smog? fact or fiction? FACT!
whats up ht, okay so i have a 91' civic hatch thats bar'd for a 91' B18A1. i currently have a 98' jdm B18B motor in there & i reused my allllll of my obd0 components on the new longblock.
The B18B has bad rings, it smokes on coldstarts and heavy acceleration. I also didnt rewire my fan switch so the radiator fan wasnt on. This is how i cheated the smog:
91' civic hatch bar'd for 91' B18A1
jdm B18B obd0 configured
timing set @ 16 degrees
stock 1.5L airbox w/ k&n filter
new random unknown brand ca compliant cat i got from a muffler shop
hedman header ( didnt even ask for the carb sticker )
i drove my car around for about an hour before hand & ran it suuuper empty, put 2 gallons of 87 octane & poured in 1 gallon of denatured alcohol while it was running. It didnt affect the idle at all, didnt smoke, the car didnt even seem to notice, but you could definitely feel a power decrease. I drove it 15 min to the smog shop in third gear & let it idle outside.
15 MPH:
max / meas
HC: 127 / 46
CO: .79 / .12
NO: 825 / 801
i checked the temp of the car after the 15 MPh test and it was overheating, the needle was halfway between NOT and max temp. i asked him to bring out the huge air circulator fans and throw it infront, it did alot better.
25 MPH
max / meas
HC: 101 / 23
CO: .68 / .08
NO: 764 / 70
IT WORKED! i passed and immediatly after leaving the smog place i went to the gas station and filled it up to try and dilute the alcohol as much as i could. Hope this helps someone.
iheartjayDem is offline   Reply With Quote
Old 03-05-2011, 02:11 PM   #2
solbrothers
y u rusty doe?
1970 Honda CB450
My Garage
solbrothers's Avatar
iTrader Rating: (1)
solbrothers
Send a message via AIM to solbrothers
Default Re: denatured alcohol to pass CA smog? fact or fiction? FACT!
How do you know uy was going to fail? You didnt necessarily cheat, you just passed
Originally Posted by 94EG8 View Post
Some guys get tattoos together, some guys go to the gym together, then there's Ash and Solbrothers: Lifetime alignments together
Originally Posted by Rguy View Post
I actually laughed. Well done sol.
solbrothers is online now   Reply With Quote
Old 03-05-2011, 02:13 PM   #3
EJeff8
TheRabbit087
Old news is really old news.
EJeff8 is offline   Reply With Quote
Old 03-05-2011, 02:18 PM   #4
solbrothers
y u rusty doe?
1970 Honda CB450
My Garage
iTrader Rating: (1)
solbrothers
Op hates thieves but loves ed6's
Old 03-05-2011, 02:33 PM   #5
iheartjayDem
if you saw the way it burns oil you'd know it would fail too. Last week it was blowing out so much smoke it killed a semi-new o2 sensor in a week, i replaced it yesterday.
Old 03-05-2011, 02:33 PM   #6
iheartjayDem
lol yeap
Old 03-05-2011, 02:36 PM   #7
Ajax
Ajax's Avatar
15 MPH:
max / meas
HC: 127 / 46
CO: .79 / .12
NO: 825 / 801
25 MPH
max / meas
HC: 101 / 23
CO: .68 / .08
NO: 764 / 70
You have a B18B1 that has bad rings and overheats and you are worried about it passing smog?
Ajax is offline   Reply With Quote
Old 03-05-2011, 02:37 PM   #8
slomofo
GDD Member
1991 GTR .
slomofo's Avatar
iTrader Rating: (1)
solbrothers xtrac1 George Knighton ILcrxsi1 uncle_ben
Send a message via ICQ to slomofo Send a message via AIM to slomofo Send a message via MSN to slomofo Send a message via Yahoo to slomofo Send a message via Skype™ to slomofo
This thread is misleading information because the smog test has different fields. NOx is not positively affected by alcohol, only hydrocarbons and CO. Get the mixture of alcohol wrong and you could fail NOx if your HC drops too low and you start running too lean.
Alcohol works for some, but not all. If a car like a Dodge with a 318 or 360 is failing for what they typically fail for which is NOx and you suggest to them that they run alcohol, their NOx numbers will get worse and they'll risk damage to their catalytic converters. The risks of everyone running alcohol are too great because not everyone is an emissions (smog) expert and using it inappropriately could result in damage of catalysts, oxygen sensors, and even engines; this is why I never suggest it to anyone.
Originally Posted by turbohatch96y7 View Post
I love a good creampie!
slomofo is offline   Reply With Quote
Old 03-05-2011, 02:38 PM   #9
slomofo
GDD Member
1991 GTR .
slomofo's Avatar
iTrader Rating: (1)
You'd be surprised how many smoky cars pass and how many seemingly clean cars fail.
Old 03-05-2011, 02:38 PM   #10
stackz
at the jetties fishin'
stackz's Avatar
And yet you still want to run this piece of ****?
It is the soldier, not the reporter, who has given us the freedom of press.
It is the soldier, not the poet, who has given us the freedom of speech.
It is the soldier who salutes the flag, who serves beneath the flag, and whose coffin is draped by the flag, who allows the protestors to burn the flag.
If you can read this, thank a teacher.
If you are reading it in english, thank a VETERAN.
stackz is offline   Reply With Quote
Old 03-05-2011, 02:51 PM   #11
iheartjayDem
im borrowing this engine to get my tags because thats what its bar'd for. once i get my tags, i can reswap it with the itr swap waiting in my garage & im good for 2 years. I shouldve tried to smog it without the alcohol, but i didnt because im impatient. i found a lot of mixed opionions so i decided to try it for myself & it worked. why not add another good testimonial for someone that could be skeptical on trying it themselves?
Old 03-05-2011, 04:12 PM   #12
BryanM.
Resident Gearhead
2007 Honda Civic
BryanM.'s Avatar
iTrader Rating: (1)
Wouldn't it be grand if more people beat the system and continued to pollute the air using tricks like this? Great info
PICS: '07 FG1 - DD
......... '96 EJ6 - SOLD
......... '92 EH2 - SOLD
BryanM. is offline   Reply With Quote
Old 03-05-2011, 05:32 PM   #13
solbrothers
y u rusty doe?
1970 Honda CB450
My Garage
iTrader Rating: (1)
solbrothers
this
Old 03-05-2011, 05:37 PM   #14
racebum
2002 Chevrolet Corvette
racebum's Avatar
Racebum
Send a message via AIM to racebum Send a message via Yahoo to racebum
so you're doing all this swap labor just for tags?
i can't believe the trouble some of you go to in order to keep old cars going
Mountain View Carpet Cleaning also found at carpet cleaning beaverton Do you own a turbo honda? see turboinstall.net
racebum is offline   Reply With Quote
Old 03-05-2011, 06:24 PM   #15
iheartjayDem
yess i am, this situation doesnt pertain to only older cars. any one that swapped a bar'd car with something else has to pull that engine out, swap, then reswap. so i guess im the type of person that loves their car enough to do something consuming as **** like this lol
Old 03-06-2011, 09:09 AM   #16
BIGBLOCKEK
BIGBLOCKEK's Avatar
Send a message via AIM to BIGBLOCKEK
or you COULD have just properly swapped the b18c5 with all necessary smog equipment and have it bar'd for that swap.
2000 s2000 unmolested/hardtop
2007 Silverado (new body style) regular cab short bed v8
2013 Fit sport
BIGBLOCKEK is offline   Reply With Quote
Old 03-06-2011, 09:26 AM   #17
mrdeadman
mrdeadman's Avatar
OP had a civic though...
Big Dick Swinger Club member #[002]
mrdeadman is offline   Reply With Quote
Old 03-06-2011, 12:51 PM   #18
iheartjayDem
buuuut i didnt feel like sourcing out a clean usdm b18c5, so i got a clean b18c itr which was 1000 times easier to find
Old 03-06-2011, 01:20 PM   #19
TEGGSRB18C1
1997 Honda Accord
TEGGSRB18C1's Avatar
Fvcking California. Are the girls there that hot? Is the weather that nice?
2000 NHBP DC2 56K OG MILES/GARAGE QUEEN - SOLD
1997 EGP CD5 146K LESS AND LESS SHITTY EVERY WEEKEND - DD
TEGGSRB18C1 is offline   Reply With Quote
Old 03-06-2011, 01:52 PM   #20
solbrothers
y u rusty doe?
1970 Honda CB450
My Garage
iTrader Rating: (1)
solbrothers
yes and yes
Old 03-06-2011, 03:09 PM   #21
TEGGSRB18C1
1997 Honda Accord
Originally Posted by solbrothers View Post
yes and yes
*starts packing*
Old 03-06-2011, 03:29 PM   #22
kidcool1977
SHAME ON YOU REBECCA!
kidcool1977's Avatar
*starts packing*
I've been to cali. as SOL said it is a different world then York pa (no offense),personally I'd rather go to Florida girls there are MUCH HOTTER!
sent from my laptop in the comfort of my house.
kidcool1977 is offline   Reply With Quote
Old 03-06-2011, 04:47 PM   #23
MonkeyMagic
MonkeyMagic's Avatar
Send a message via AIM to MonkeyMagic
first thought, then...
but that would make sense? amirite?
MonkeyMagic is offline   Reply With Quote
Old 02-02-2013, 01:14 PM   #24
Rudy N Alvarez
I agree if you hit up south beach
Rudy N Alvarez is offline   Reply With Quote
Old 02-02-2013, 01:18 PM   #25
doood
been there done that
2005 Acura RSX
doood's Avatar
iTrader Rating: (1)
get the **** out
Originally Posted by Chief Brody View Post
Sometimes I think Fiji having access to the Internet scares me more than most Americans having access to firearms
Originally Posted by 213374U View Post
We can be gay together bro
doood is online now   Reply With Quote
adding, alcohol, catalitic, clean, converter, crx, denature, denatured, hc, honda, idle, pass, smog, test, works
