Old 03-05-2011, 12:50 PM   #1
hefftone79
hefftone79's Avatar
Default Bolt on Catalytic converter for EG w/ B18B1 swap
I need a catalytic converter for my 93 Civic CX with B18b1 swap. I'm using the stock B18b header, I have an aftermarket exhaust, but no cat (nor test pipe)
I know that the flanges are rotated between some integras and civics...Is there a stock bolt-in CAT that will fit (aligned bolt holes and proper length). Will a stock integra CAT fit? I need to get emissions done, and plan to keep the car NA during break-in then finishing up the turbo, with a down pipe and 2.5" Cat. But until then, a stock cat will get me by.
Current Rides:1993-Civic CX B18B1--awaiting T3; 1993-Chevy S10--2.8l; 1997-BMW M3 Sedan 1998-Yamaha YZF600R
Former rides:1990 Integra GS, 1994 Integra RS, 1989-Civic Si #000015
hefftone79 is offline   Reply With Quote
Old 03-05-2011, 12:56 PM   #2
tlarimer
2007 Honda Civic
My Garage
tlarimer's Avatar
iTrader Rating: (3)
Default Re: Bolt on Catalytic converter for EG w/ B18B1 swap
I used a OEM B16A header on my B18B1 in my EH3, it was tight but fit and allowed me to use the OEM EH3 cat and exhaust system.
Edit: When I say tight, I mean to the front of the block and oil pan. I had to give a few love taps with a ball peen hammer to one of the lower pipes to get it to clear the block. But it was a temporary engine for me, just needed to get it running.
FS:92 Civic Si parts, EDM/JDM EG parts, electronics, Gathers and more
2011 Honda Crosstour EX-L Nav 4WD
2007 Honda Civic Si Sedan FBP
tlarimer is offline   Reply With Quote
Old 03-06-2011, 04:42 AM   #3
hefftone79
hefftone79's Avatar
Thanks for the reply, I don't intend on buying a different exhaust manifold/header. I'd think something will work with the setup I have, whether its Integra, Del sol Vtec, or EK Si.... Anybody know?
Old 03-06-2011, 08:00 AM   #4
blown_ss
blown_ss's Avatar
Send a message via AIM to blown_ss
a integra cat will work. i have it on my eg with a b18b1 in it.
blown_ss is offline   Reply With Quote
Old 03-06-2011, 02:38 PM   #5
hefftone79
hefftone79's Avatar
Awesome, thanks for the reply. I actually live in Dallas, Ga now. As far as the internet goes that practically makes us neighbors.
Old 03-06-2011, 05:57 PM   #6
NotAJDMFanBoy
I believe it's the JDM ITR manifold that the flange is rotated funny. You can always cut the pipe and go to an exhaust shop to get it rewelded.
matt93eg is a lying scammer. Avoid.
NotAJDMFanBoy is offline   Reply With Quote
Old 03-06-2011, 06:11 PM   #7
94EG8
Honda-Tech gave me this lousy title
94EG8's Avatar
stock LS manifold/downpipe + DX cat and catback all bolts up IIRC.
"Bacon tendercrisp chicken, the most powerful sandwich in its class."
Per ardua ad astra
My F/S thread -> http://hondamarketplace.com/showthread.php?t=2900962
Originally Posted by Knightsport View Post
Hello,
This is Knightsport, from the internet. I will be out of the internet from June 2 and returning on June 11th. In my absence I suggest you pray as there can be only one Knightsport from the internet.
Thank you and God Bless,
-Knightsport
94EG8 is offline   Reply With Quote
Old 03-21-2011, 06:03 PM   #8
hefftone79
hefftone79's Avatar
I ordered an integra LS "test-pipe" from ebay and the flanges are not lining up....
So frustrated!
Old 03-22-2011, 02:37 AM   #9
rhymeshark916
rhymeshark916's Avatar
ibr Sasquatch
Send a message via AIM to rhymeshark916
Whatever cat. converter you get, if it's doesn't fit then you know what to do. That's the simplest answer to your question. When doing engine swaps, not everything is going to fit between different chassis. Usually, you're b-pipe needs to be shorten.
92 EH2 BARD B18C1 GC KONI 5x114.3 15" GM ITR
rhymeshark916 is offline   Reply With Quote
Old 04-30-2011, 12:18 PM   #10
hefftone79
hefftone79's Avatar
Trying to figure out what actually fits,.....since I don't have anything to work with at the moment, I will have to buy one......I rather be closer than farther away from gettting this on the road.
Old 05-13-2011, 02:58 PM   #11
hefftone79
hefftone79's Avatar
I ordered a bosal converter for a 94 integra Ls.... it is the correct length, but the three bolt flange is slightly cocked. Converter body seems a little bigger, and may contact the suspension subframe.
I stopped at autozone, picked up a converter for a del sol (basically the same as a civic)...the one I got is Maremont 29132...it is sold as direct-fit, but the three bolt flange is made to slide in to the catalytic converter, then be clamped. This makes clocking the flanges a breeze, but the converter is a tad short (16.5" long) for the clamp, but MIGHT work if welded.....at least this saves having to cut (straight) and reweld..... the pipe diameter does seem a little small, the rear end of the converter is 1-7/8" (ID) pipe, but the pipe that slides into that (with the 3-bolt flange) is 1-5/8" (ID).... That's not exactly ideal stepping up from 1.625 to 2.50....
Another option is Maremont 29183 (for 1995 integra LS), which my autozone rep said is "unavailable through them" (so use google)...... this one is 17.6 inches long so it should be easy to clock and clamp. It uses the same two piece design.
Old 05-13-2011, 03:13 PM   #12
hefftone79
hefftone79's Avatar
a better picture....
18, b18b1, cat, catalytic, chevy, civic, converter, exhaust, fits, hatch, honda, kind, pipe, s10, s2000, swap
