P1336 code! Please help
Old 03-03-2011, 06:33 AM
ser3100's Avatar
Default P1336 code! Please help
Hello all. New to the boards so whats up to all. Hoping you all can help me out. My wifes 2000 integra LS sedan is throwing a CEL P1336 code (manufacturer controlled ignition system or misfire) and i cant figure it out. I just changed oil, spark plugs, wires, cap & rotor and cleaned the CAI air filter. I cleared the code and ran the car for about 30 min and the code did not come back. Today i go to start the car and the damn code shows up again. What else should i be looking at? Car runs fine and starts fine. I dont want the car to crap out on her on the freeway so i need your help. Thanks.
Old 03-03-2011, 08:13 AM
vrrodri's Avatar
Default Re: P1336 code! Please help
Not sure this helps you narrow it down but here is what this code is about:
P1336 Engine Speed (RPM) Fluctuation Sensor Intermittent Interruption
Sounds like one of the sensors (possibly inside the dizzy) is going bad on you.
Old 03-03-2011, 03:39 PM
ser3100's Avatar
OK but when i scanned it, it came up with manufacturer controlled ignition system or misfire. I thought these two errors were different from each other. If it is the sensor your talking about, is it easy to replace? Thanks
Old 03-03-2011, 04:49 PM
vrrodri's Avatar
If it's the igniter inside the dizzy it is not hard , it depends on what it is really. Buy a Helms manual and it should walk you through the test steps.
Old 03-04-2011, 04:47 AM
ser3100's Avatar
Please excuse my noobness but what is a dizzy? Are you talking about the distributor?
Old 03-04-2011, 04:48 AM
vrrodri's Avatar
yup
Old 05-13-2011, 06:50 PM
BWFL's Avatar
Sorry to ask, i'm having the same code here, but i need my car for work and have absolutly no alternative, can ya point me in the direction for any how-to's and also is this going to be hard on the car itself?
93CharcoalHatch
20
04-20-2006 05:42 AM
South sol
11-04-2003 06:55 PM
EK_vzla
10-08-2003 11:20 AM
Quick Reply: P1336 code! Please help
