D16Y7 Idle problem
Old 03-02-2011, 05:22 PM
99ek4Dr's Avatar
Default D16Y7 Idle problem
i have the same problem my cel is on and codes are map sensor high input and tps low input. my friend cut my map and tps wires right near the connector i nicely put the connections back and tested the voltage..when i start the car the idle surges about the same in the video posted but faster and it sounds like a leak near the throttle body i have a d16y7...any help? mine does this when idles and dies right when i try to drive it
Old 03-02-2011, 05:35 PM
99ek4Dr's Avatar
Default Re: IDLE problem with 1996 civic
mine do
Old 03-02-2011, 05:37 PM
Former User's Avatar
Are the TPS and MAP sensor connectors swapped?
Old 03-02-2011, 05:43 PM
99ek4Dr's Avatar
i switches the sensors and car sounded like there was some sort of missfire or something it had a deep idle every few seconds i dont know how to describe
Old 03-02-2011, 05:45 PM
99ek4Dr's Avatar
i also checked for a leak around the manifold and there was nothing..it sounds like a whistle or humming noise coming from throttle body. thats why im thinkining maybe t/b gasket leak. I dont think that would cause my car to have the problems its having though
Old 03-02-2011, 05:49 PM
What are the three wire colors in each connector currently plugged into the MAP sensor and TPS?
Old 03-02-2011, 05:55 PM
99ek4Dr's Avatar
i dont remember now but the wires that were cut i put back by matching the colors..i know that is right for a fact i checked about 50 times lol
Old 03-02-2011, 05:56 PM
Can't help you without concrete information.
Old 03-02-2011, 05:58 PM
TB gasket costs $2. Torquing the TB nuts and bolts to spec is free if you have a torque wrench.
Old 03-02-2011, 06:05 PM
99ek4Dr's Avatar
may i also state my iacv connector that was cut off..when i unplug it the idle stop surging but still idles high...when i unplug tps sensor it also stops the surging..its only when there both plugged in that the idle surges i still cant drive with the connectors disconnected it dies right away i also noticed an odd smell in my exhaust like the cars not getting the right air/fuel ratio
Old 03-02-2011, 06:22 PM
99ek4Dr's Avatar
Default Re: D16Y7 Idle problem
any ideas ron?
Smiley Loc
05-11-2018 01:15 PM
BiG_DeE
05-19-2008 06:56 PM
heyitzspikey
01-29-2007 09:19 PM
mikeunreal
10-26-2005 05:31 PM
Quick Reply: D16Y7 Idle problem
