Replacing Inner Tie Rod on Del Sol, Info needed
Old 02-25-2011, 06:16 AM
fracas's Avatar
Default Replacing Inner Tie Rod on Del Sol, Info needed
I have a bad tie rod on the passenger side on my 97 Del Sol. Took it to a shop and they wanted to replace the Tie Rod, Wheel Bearing, and do a Alignment For $486. I said HELL NO. I have another knuckle with a good bearing that Im going to swap today. But I wasnt 100% sure how to replace the Inner Tie rod .
And write ups will be helpful
AND YES I KNOW it will need a alignment after the parts are installed. I do not plan on driving the car to the shop. I have a trailer that will be used.
Old 02-25-2011, 07:38 AM
The Grumpiest
grumblemarc's Avatar
Default Re: Replacing Inner Tie Rod on Del Sol, Info needed
Originally Posted by fracas
I have a bad tie rod on the passenger side on my 97 Del Sol. But I wasnt 100% sure about the Inner Tie rod on replacing it.
I don't understand. If the tie rod is bad why would you NOT replace it? Period. Are we talking about the OUTER tie rod that is bad?
http://www.hondacivicforum.com/forum...ad.php?t=60825
Old 02-25-2011, 07:41 AM
CivicxTree754's Avatar
Its not that hard and if you put some tape around the threads up to the bolt, you wont be off by much at all when you replace the tie rod. It a 3 tool affair lol. Proper size combination wrench, pair of vice grips, and a hammer. Oh and the socket for the tie rod end bolt. GL
Old 02-25-2011, 07:47 AM
fracas's Avatar
The whole tape idea applies with the outer right?. Im needing to replace the inner and wasnt sure how it was bolted to the rack & pinion.
Old 02-25-2011, 07:54 AM
fracas's Avatar
Thanks for that link. That will help me get it apart. My inner is bad and will be replaced today. Outer tie rod is fine and is in good shape.
Old 02-25-2011, 01:46 PM
fracas's Avatar
Thanks again for the info guys. I replaced my inner and outer tie rods in no time. Simple and easy and the link helps out.
Astronaughty
13
12-29-2014 06:48 PM
andybmuzik
11-03-2011 03:37 PM
gen2tegboi
25
04-03-2010 01:38 PM
rasinhell
05-03-2005 09:23 PM
Quick Reply: Replacing Inner Tie Rod on Del Sol, Info needed
