how do you tighten a gsr timing belt
Old 02-24-2011, 01:52 PM
CYDALKIDD's Avatar
Default how do you tighten a gsr timing belt
i know its suppose to be loose on either the exhaust or header side, but mines i think is too loose. how do i tighten it?
Old 02-24-2011, 03:19 PM
weavertime1's Avatar
Default Re: how do you tighten a gsr timing belt
Take everything apart on the timing belt side and see how the tensioner looks. The belt may have stretched over time as well, who knows!?
Old 02-25-2011, 06:34 AM
N/A
Purpose Built
N/A's Avatar
Your belt should not bend no more or no less than 90 degrees when tightened properly
If it just loosened randomly, park it and go order yourself a new timing belt, water pump, and tensioner
Old 02-25-2011, 09:01 AM
C-Rex1021's Avatar
Agreed. Don't want to f*@k up the motor over a loose timing belt.
Old 02-25-2011, 03:16 PM
true story!!
Old 02-25-2011, 09:15 PM
sayanything's Avatar
tightening it only involves rotating the camshaft sprockets 3 teeth counterclockwise, by rotating from the crank pulley, then tightening the tensioner bolt(it has to be loosened, but not removed beforehand). The spring for the tensioner, and the tension that will be created by rotating 3 teeth is what the timing belt tension should be.
Old 02-25-2011, 09:42 PM
sirtef9's Avatar
X2
Old 02-26-2011, 05:03 AM
N/A
Purpose Built
N/A's Avatar
Not trying to bash, but think if you were a beginner and never did a timing belt,
What would u think the first time u read your instructions you just posted?
Old 02-26-2011, 12:26 PM
^Haha got it. Cliffs:
*open hood.
*if you have cruise control, that box needs to be moved. (3) 10mm bolts.
*remove (2) 12mm bolts holding timing belt cover on.
*loosen(but dont remove) 14mm nut for tensioner. google to find where it is.
*use 19mm socket to turn crank pulley bolt counterclockwise until you see that the cam gears have rotated 3 teeth.
*tighten 14mm tensioner bolt
*at this point you can check the tension by twisting it as mentioned above.
*replace cover
Old 02-26-2011, 01:35 PM
JThrasher79's Avatar
*open hood.
*replace cover
lol..
Old 11-20-2011, 06:17 AM
95tegbuild's Avatar
Originally Posted by JThrasher79
lol..
idk what bolts are in your timing cover but mine is held together with 10mm bolts
Old 05-12-2013, 05:00 PM
way2aware's Avatar
Icon6 Re: how do you tighten a gsr timing belt
*open hood.
*replace cover
Thanks man..
Old 05-12-2013, 06:47 PM
m4xwellmurd3r's Avatar
rmember to priperly torque the 14mm tensioner bolt to 43ftlb. im not joking its a lot more torque than you think it is, and you will punch yourself for not torquing it down properly when your belt comes loose and bends all 16 valves
Posted from Honda-tech.com App for Android
Old 05-12-2013, 07:24 PM
S2BumpsticksGSR's Avatar
Way 2 aware- that name bit you in the ***!
Look at the dates -2011
Old 05-12-2013, 11:05 PM
lmao i didnt even notice. but i use forum reader and the date font is really dark
Old 05-12-2013, 11:24 PM
Coopa B18c5's Avatar
Originally Posted by way2aware
Thanks man..
hahaha my dudes thanking him
Old 05-13-2013, 06:19 AM
pimpwagon's Avatar
You might think he looks like a fool. I see someone who used the SEARCH function...
Old 05-13-2013, 10:17 PM
thats what i see too. props to the thread reviver for using the search function to find his answer instead of starting a new question thread to a common question.
slide inside
10-22-2009 09:25 AM
chahsiubow
12-14-2007 10:01 PM
faSHOwidIT
02-25-2006 03:00 AM
Quick Reply: how do you tighten a gsr timing belt
