What's the WIDEST Tire I can fit on 5th Gen?
Hello,
I've been searching, but can't seem to find the info i'm looking for. Widest tire that will fit.
5th Gen Accord: 1994 Accord LX Coupe.
Can I fit a 225/50/16? Without running into clearance issues? If that's too big, 215/40/16?
Thanks.
Not too worried about the speedometer being out, it's far out already from the swap. Can i fit this tire? Planning on using a 16"x7" with a 40mm offset.
Complications? Hoping to achieve without modification. Not lowered at this point. Planning on using Tein SS coilovers in the future.
Thanks.
Re: What's the WIDEST Tire I can fit on 5th Gen?
my tires rub and i'm on 215/50/17 but i'm also 2.5" lower. you may be able to fit those tires though because they are 16s...not sure, however, you will have issues when you lower
make sure the wheels will fit on the lug studs. that wheel looks like it has 8 holes for lugs. which i suppose would fit if you have 4 lugs right now, but it would be really dumb
ps am i using the word "lug" correctly?
special one for a reason? lol
It has 8 holes, because it has two bolt patterns. 4x114.3 & 4x100
You only use 4 bolts at a time.
It can interchange between my cars, which can make use of the wheel using the applicable pattern.
Depends on the amount of work you want to do, on another forum there is a guy with 9.5 inch wide rims, or 10...
I run a 195,50,15 on a 15" xxr +15mm offset rim. Moving up to 16's in the rear or maybe full around, and when I do, same tire size, and you won't have rubbing issues from what I have heard.
40 mm offset and your wheels are in the fenders..depends the look you are going for too, any stretch?
^Please, May I ask to see a PICTURE sir. I'm interested in learning more info on the suspension setup your running. Specifically what coil overs? I would like to run 18s on my 94 someday..
IMO, just get the proper size tire for the car: 205/50/16
Running 225's isnt going to net you much performance gain on a daily. its not worth the fitment issues and rubbing that probably come along with the bigger tire
and definitely don't lsiten to this guy. 195/50/15 is 1.5" (over 6%) smaller than the factory tire. that accord probably looks ridiculous with tiny civic sized tires on it. sounds like he is one of those wannabe vw, low offset, stretched tire kinda guys
There you go, this was back when it was raised up a bit to clear speed bumps at school but then I said **** it I can walk and dropped it down back to where the fender's right on top of the tire lol. I don't have a pic of it dropped like recently tho but I can get one if you wished
I have 95 accord on 16x8 with +15 offset and running 205/40/16...and im pretty low and i dont rub. No camber or fender roll.
I had been running 225/45/17 on 17x7 rims with a +42 offest. Right now I have 215/45/17 on 17x8 rims with +45 front and +35 rear. The issue for me is the rim (and tire) to trailing arm clearance on the 8 inch rims if using +45 on the rear. +40 seems about right for front and rear but I can't get it in a rim I like.
2000Accord5sp
10-25-2002 05:04 AM
