Old 02-20-2011, 02:28 PM   #1
rridc
Default my 97' accord wont shift into any gear?? HELP!!
hi all, hope someone can help me here before I go and get a used tranny (97' accord, ex, auto). So I was at the red light one day and light turns green and car wont move? Wont shift into any gear after that, from one moment to another. Honda dealer says get new tran. someone told me that's odd and never heard of a Honda do that he told me to check the shift cable and everything seems to be fine. Someone said shift solenoid but then someone else said that if it were the solenoid it will still shift into 1st at least or reverse something like that. I took good care of the car and it only has 100 thou. on it and it turns on like normal everything fine except it wont even hiccup when i move the shifter absolutely nothing. Any help would be greatly appreciated.
Rich.
rridc is offline   Reply With Quote
Old 02-20-2011, 03:46 PM   #2
phootbag
phootbag's Avatar
Default Re: my 97' accord wont shift into any gear?? HELP!!
Are you CERTAIN the shift cable is connected and turning the manual valve? I suspect an electrical problem. Check for DTC's then proceed with other troubleshooting.
Originally Posted by phootbag View Post
A "dizzy" is that magical thing you replace when your car wont start.
Originally Posted by chrisff521 View Post
Ok so youre saying I should replace the whole "dizzy" ?
phootbag is offline   Reply With Quote
Old 02-20-2011, 03:54 PM   #3
rridc
I got under and took off the plate where the cable goes into the tran. and had somebody move the shifter and its moving the lever where its connected. What are DTC's, sorry noobe to abbreviations.
Old 02-20-2011, 04:03 PM   #4
phootbag
phootbag's Avatar
The vehicle is OBD 2 ( On Board Diagnostics generation 2 ). This means the computer monitors a TON of data and can identify when many different problems exist. If there is an electrical problem or various mechanical problems the vehicle will set a DTC ( Diagnostic Trouble Code ). Before spending too much time I would check for a DTC in the system as it may help direct your efforts if one existed.
Old 02-20-2011, 04:40 PM   #5
rridc
Im gonna borrow a computer code reader from a friend and I'll check the codes i'll post them up in a little while, the dtc's. Thank you for your interest Phoot. i
Old 02-22-2011, 10:47 AM   #6
rridc
the car is not giving any code, no CEL?
Old 02-24-2011, 02:39 PM   #7
rridc
so pretty much I guess ill have to get a new tranny. I thought this was "Honda-tech" like people who knew about HONDA Tech issue's guess not.
Old 02-24-2011, 04:56 PM   #8
UgandaHonda
if it starts and idles but dosent engage sounds like a broken cv axle to me just my .02 cents
UgandaHonda is offline   Reply With Quote
Old 02-24-2011, 05:30 PM   #9
phootbag
phootbag's Avatar
You already got more than you paid for here, *******.
Old 02-25-2011, 09:16 AM   #10
rridc
hey phootsy i got exactly what i paid for nothing u ****ing dick act like u know something and dont know ****. so just mind ur ****ing business if u dont know what the problem is ASSHOLE!!!
Thank you for ur .02 cents uganda.
Old 02-25-2011, 11:35 AM   #11
nus_dogg
1994 Honda Accord
nus_dogg's Avatar
Have you check if the auto tran's low on fluid? My dad's '94 Accord EX pressure ATF line has hole in the line for some reason and all the fluid came out while he's at the red light waiting. So then he tries to go but it wouldn't even move. The car would start and rev but no movement of the car. Then as I did a inspection, I found that there's a cut in the pressure ATF line. So yeah, thought I wanted to share.
1994 Honda Accord EX - JDM H22A
- 204whp/157wtq
Originally Posted by toycar View Post
Breaking the bank, maybe. Feeling like a boss, likely.
nus_dogg is offline   Reply With Quote
Old 02-25-2011, 02:38 PM   #12
phootbag
phootbag's Avatar
Take your sense of entitlement and stick it up your backside.
Old 02-25-2011, 03:51 PM   #13
CDdubz5
1996 Honda Accord
CDdubz5's Avatar
Send a message via AIM to CDdubz5
i had an axle "pop out" of the trans in my old integra. it would just rev regardless of gear until eventually it would not shift into gear. check your cv joints. also check trans fluid and pressure lines
BUILT NOT BOUGHT#8|REJECT☆SQUAD#69-OG|SOHC☆SQUAD|HI! SOCIETY|BTS#10
Originally Posted by 91 crx savage View Post
Cop-"so you draggin in this thing?" "no I still got the stock motor" cop-"no I mean over bumps"
CDdubz5 is offline   Reply With Quote
1994, 1996, 1997, 94, 97, accord, engage, gear, gears, honda, manual, shift, shifting, v6, wont
