97 Civic - wouldn't lock manually or with power lock and then broke arm off actuator
Old 02-20-2011, 09:22 AM
poptheclutch's Avatar
Default 97 Civic - wouldn't lock manually or with power lock and then broke arm off actuator
I've got 97 civic 4 door that I can't figure out the door locks on. Started out with the drivers door wouldn't lock manually or with power lock. All the others worked fine. Lock worked with key only. I forced the lock **** one day and broke the arm off the actuator. I just replaced the lock assy & actuator with a used one. Now the front door locks work sometimes. The driver door will only lock when closed. The pass side will lock/unlock manually ok, but the power lock will work a few times then stop working. The rear doors work fine. Could this be the lock module ?
Thanks
Old 01-10-2013, 05:48 AM
Micah_Dude's Avatar
Default Re: 97 Civic door locks
Not to awake something dead, but I'm having this same problem - minus breaking the arm off actuator. Is there anyone out there who thinks it may be the actuator causing the lock issue? I'm about considering buying a new one to see if it fixes the problem, but I don't want to waste my money.
Old 01-10-2013, 06:18 AM
Former User's Avatar
If you have difficulty unlocking/locking the door manually, then first fix that mechanical problem before considering the actuator.
Eormek
05-20-2016 04:46 PM
SteveW
02-21-2007 01:48 PM
splitime
11-01-2002 01:02 PM
joemama
09-13-2001 03:34 PM
Quick Reply: 97 Civic - wouldn't lock manually or with power lock and then broke arm off actuator
