Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda CRX / EF Civic (1988-1991)
Old 02-16-2011, 11:01 AM   #1
killa69er
1993 Honda Civic
killa69er's Avatar
Send a message via AIM to killa69er
Default whistling sound?
Okay so my 91 civic is making a whistling sound under light acceleration I haven't heard it while I'm sittin at idle but it's very annoying as a drive has anyone ever encountered this problem I need help tracking it down any help would be appreciated
killa69er is offline   Reply With Quote
Old 02-16-2011, 11:21 AM   #2
4drEF
4drEF's Avatar
Default Re: whistling sound?
Bubb Rubb?
Does it only do it while in gear or can you hear it while coasting in neutral?
All of my posts should be considered for being made into a sticky.
4drEF is offline   Reply With Quote
Old 02-16-2011, 11:49 AM   #3
VAZQU3Z90R3X
VAZQU3Z90R3X's Avatar
Dude its Normal i bet you have a cheap filter on ur intake right? anyways just upgrade to a name brand filter like aem or k&n and problem solved Good Luck..
VAZQU3Z90R3X is offline   Reply With Quote
Old 02-16-2011, 11:52 AM   #4
KINGVEM^^ED6
1991 Honda Civic
My Garage
KINGVEM^^ED6's Avatar
iTrader Rating: (1)
damn thats harsh for ur first post^
if u dont have a aftermarket intake
check the hose going from the head to the intake tube
mine was doing the same **** last week
Originally Posted by tonylovesjdmEF9 View Post
i would choke my ex it was pretty fun and wild
KINGVEM^^ED6 is offline   Reply With Quote
Old 02-16-2011, 11:59 AM   #5
VAZQU3Z90R3X
HARSHH DOGG LIKE BUNK WEED LOL BUT A SIMPLE FIXX JUST BEiNG FRANK.. PIECE iT
Old 02-16-2011, 12:11 PM   #6
nineohnine
nineohnine's Avatar
i got the same problem to on my ls swap never did it before the swap (with same intake/filter) but has always done it AFTER the swap... and i have no idea what it is... tho i have just learned to deal with it
nineohnine is offline   Reply With Quote
Old 02-16-2011, 12:29 PM   #7
killa69er
1993 Honda Civic
killa69er's Avatar
sorry about no to maybe details... i was posting this from my phone..
91 civic zc sohc stock air box.. and fram filter it just started this.. and it kinda sounds like its under the dash somewhere?
i bought the car from a kid that "tried" to wiretuck it and i have been routing wires and vac line and trying to get them in the right spot..
if i give it a little gas on the highway i can hear it. if i give more gas it goes away. and then also when i let off the gas it goes away as well..
Old 02-16-2011, 12:41 PM   #8
stackedhouse
1991 Honda Civic
stackedhouse's Avatar
there should be a little screw on the throttle body unscrew that a little fixed my whistling problem
neighborHOODFABrication
stackedhouse is offline   Reply With Quote
Old 02-16-2011, 01:40 PM   #9
LudeEFv2.4
My old title sucked.
2000 BMW M5
LudeEFv2.4's Avatar
Hopefully you will not last long.
///M5
LudeEFv2.4 is offline   Reply With Quote
Old 02-16-2011, 04:07 PM   #10
99_Taco_Supreme
99_Taco_Supreme's Avatar
Throttle body spacers make a whistling noise sometimes. You have one of those installed?
99_Taco_Supreme is offline   Reply With Quote
Old 02-16-2011, 05:06 PM   #11
killa69er
1993 Honda Civic
killa69er's Avatar
no tb spacer as i said sounds like inside the car? under the dash or near the cluster
Old 02-16-2011, 06:37 PM   #12
KINGVEM^^ED6
1991 Honda Civic
My Garage
iTrader Rating: (1)
might be ur intake mani. gasket heard that before
Old 02-19-2011, 11:27 AM   #13
91ef-si
91ef-si's Avatar
Unscrew the screw on the throttle body a little bit and that should fix it. But if it doesnt start checking for vacume leaks
1993 Del sol (my new adventure)
1991 civic si---teal--- (traded for my eg, will regret that forever)
91ef-si is offline   Reply With Quote
Old 02-19-2011, 03:22 PM   #14
sde780
sde780's Avatar
Send a message via AIM to sde780
inb4 "my cars idling real low help!"
it's probably your intake mine did it on my GSR and my prelude does it too. With no intake on the throttle body it still whistles
2012 Tacoma DCLB
https://www.youtube.com/user/shengdama?feature=mhee
sde780 is offline   Reply With Quote
1991, 2010, acceleration, car, civic, dash, dashboard, honda, making, noise, pilot, sound, vac, whistle, whistling
