Old 02-14-2011, 09:47 AM   #1
elliascool
elliascool's Avatar
Default How many miles can u go on empty?!?!
im my 97 accord 4dr auto ..... i would always go a few miles after the yellow gas light would go on but since i havnt drove it in a long time i forgot .... is there an exact number of miles u can go with the yellow gas light on? or the point where u cant start your car anymore ?!?!?!
elliascool is offline   Reply With Quote
Old 02-14-2011, 09:57 AM   #2
quickster
Default Re: How many miles can u go on empty?!?!
I've driven 40miles once, but I wouldn't push it past 50. I never let my gas get below a half tank though if I can help it. The deposits at the bottom are most likely abrasive to your cars fuel system. It also would depend on how hard you are on the gas pedal. When I drove 40 miles it was on the freeway.
I own a 1991 Honda Accord LX 2.2 145k miles
quickster is offline   Reply With Quote
Old 02-14-2011, 09:57 AM   #3
361 accord
2000 Honda Accord
361 accord's Avatar
facebook.com/361accord epictuning
Send a message via AIM to 361 accord
30 miles-because it will go further but then the engine shuts off when you brake there is so little gas
CG squad member #001
Originally Posted by cetcivic View Post
I need my injector serviced
Only female need apply
361 accord is offline   Reply With Quote
Old 02-15-2011, 01:37 PM   #4
kd97accord
kd97accord's Avatar
last summer, when the light stayed steady on, i went just over 100kms
1997 Accord EX (CAN) 4dr
I/H/E, F1 Racing Stg 1 Clutch + 11 lb flywheel
kd97accord is offline   Reply With Quote
Old 02-15-2011, 02:31 PM   #5
accordmatt
l think car will go 45 miles but suppose to cut off 3 times before ur done. and its not a good idea at all. all the dirt and junk in bottom of tank will clog injectors or possibly worse
accordmatt is offline   Reply With Quote
Old 02-15-2011, 08:49 PM   #6
holmesnmanny
I'll guess 0 miles ? I might be wrong though.
91 Accord w/ H22A swap: Newest update on CARB cert...... Passed smog at the REF...Offically CARB certified !!!
holmesnmanny is offline   Reply With Quote
Old 02-15-2011, 08:50 PM   #7
holmesnmanny
Seriously, though, I ran out of gas around 55 miles after the light came on once before but it was weird because it seemed like my clutch was going out since it only bogged when I tried to switch. It was weird.
Old 02-16-2011, 03:28 PM   #8
poorman212
My two cents. When the light comes on, fill it up. Then since you know how much the tank holds and how much you put in, you know how much gas is left....then use your gas milage (avg per tank)...and there you go. Every fuel sender will be a little different as to when the light comes one.
66 Chevelle...89 LX auto...89 LXI 5 Speed
...95 EX auto...07 Pilot 2wd
87 LX 5 Spd (sold )...88 LXI Auto (soon to be sold)
poorman212 is offline   Reply With Quote
Old 02-16-2011, 05:24 PM   #9
JohnSFerr2387
DONT TRY IT. IT ISN'T GOOD FOR THE MOTOR. ONCE YOUR HAVE A QUARTER OF A TANK FILL IT UP. NO ONE SHOULD EVER DRIVE ON SUCH LOW GASOLINE. IT MESSES UP YOUR FUEL SYSTEM
JohnSFerr2387 is offline   Reply With Quote
Old 02-18-2011, 11:34 AM   #10
darkninja11
Isnt that what a fuel filter is for? correct me if i'm wrong.
darkninja11 is offline   Reply With Quote
Old 02-18-2011, 11:36 AM   #11
elliascool
elliascool's Avatar
yea true but over time it needs to be cleaned/replaced
Old 02-18-2011, 08:02 PM   #12
nus_dogg
1994 Honda Accord
nus_dogg's Avatar
Keep doing it, and you'll be buying a new fuel pump soon. Doing it yourself would be a PITA cause you'll need to drop the gas tank to get to the pump or pay a shop which will cost you a leg and a arm to get it replace. Fuel keeps the Fuel Pump cool liked stated above.
Running it til the light comes on will cause the pump to run hot which wears it out quick!
1994 Honda Accord EX - JDM H22A
- 204whp/157wtq
Originally Posted by toycar View Post
Breaking the bank, maybe. Feeling like a boss, likely.
nus_dogg is offline   Reply With Quote
Old 02-19-2011, 09:05 PM   #13
elliascool
elliascool's Avatar
ok didnt know that thanx but dropping the gas tank is easy as heck tho so ....
Old 02-19-2011, 09:34 PM   #14
nus_dogg
1994 Honda Accord
nus_dogg's Avatar
It's not too hard but when the welded nut that holds the two bolts for the gas tank strap turns along with the bolt when loosening it, that will tell you how hard it is when you have to drop the rear sub-frame to get the tank down. It's not easy where there's snow because those bolts underneath the car are rusted to ****.
- 204whp/157wtq
Old 02-19-2011, 09:47 PM   #15
ddh052286
You can go 0 miles on an empty tank.
ddh052286 is offline   Reply With Quote
Old 02-20-2011, 12:15 PM   #16
elliascool
elliascool's Avatar
yea rusted bolts would make it impossible ...
Old 10-20-2011, 11:49 PM   #17
Broke_not_built
Drop the gas tank? O_o never took your backseat out or what lol
Broke_not_built is offline   Reply With Quote
06, 2003, 2011, accord, cal, civic, element, empty, emty, gas, gass, honda, light, miles, tank
