innovate fails again. does anyone have the previous LM2 firmware update?
Old 02-13-2011, 03:06 PM
RACEPAK's Avatar
Default innovate fails again. does anyone have the previous LM2 firmware update?
hi guys,
so i tryed to update the firmware on my LM2 yesterday to the latest version that came out last month, ( i do it every time a new one coms out)
and it dosnt work, it fails to verify the updated firmware. and now when i turn it on it freeze at the intro innovate logo)
i looked at the innovate forum and it seems more peppole have this issue,
i tryed this in a windows 7 and in xp too.
does anyone have the previous firmware update? 1.14 or 1.13 ?
thanks
Old 02-17-2011, 04:30 PM
RACEPAK's Avatar
Default Re: innovate fails again. does anyone have the previous LM2 firmware update?
Originally Posted by RACEPAK
hi guys,
thanks
anyone?
Old 09-11-2011, 02:07 PM
dsgmach's Avatar
a bit old but I have lm2b 10 110 and 112
if his will help send me an email
cheers
Old 01-30-2012, 07:25 AM
vipersal's Avatar
Old thread but may be usefull for anyone else, i am here beacuse a have the same problem.
Here are the links, just change the lat number on the new link of the firmware.
http://www.innovatemotorsports.com/s...re/lm2b110.dld
http://www.innovatemotorsports.com/s...re/lm2b112.dld
http://www.innovatemotorsports.com/s...re/lm2b113.dld
http://www.innovatemotorsports.com/s...re/lm2b114.dld
The newwest.
http://www.innovatemotorsports.com/s...re/lm2b115.dld
Old 01-30-2012, 07:44 AM
mines13's Avatar
There is nothing wrong with rev 1.15, it has been out for over a year. You can not brick an LM-2, simple connect it to a different computer and re-flash the 1.15 firmware if you wish to upgrade. You can always run LM programmer in compatibility mode if you are having issues. If that does not work you can always call Innovate directly.
Old 01-30-2012, 07:52 AM
vipersal's Avatar
How can run it in compatibility mode ? thanks.
Old 01-30-2012, 08:18 AM
mines13's Avatar
Right click on the executable, select properties, then click on the compatibility tab. Select a previous version of windows on the drop down then launch.
Old 08-05-2014, 04:44 PM
LudeBob89's Avatar
Found this thread after experiencing the same issues.
In the end I've managed to do the update with a Win7 32 bit based laptop.
I did not use any compatibility setting on the PC.
Firmware 1.17 now installed successfully.
Worth noting it failed on Win7 64 bit based PC's.
Several attempts to contact Innovate were met with no response. Unimpressed.
Might help someone in the future.
Old 08-05-2014, 06:58 PM
met
met's Avatar
Their products are buggy and every time someone asks which brand to buy I say not innovate and get bashed for it. I do admit the lm2 is a bit better than the older stuff. Pretty much with this stuff if your meter ecu etc... or whatever is working fine don't upgrade the firmware.
kris29
01-11-2019 06:57 AM
sippncld1z
01-17-2017 12:32 AM
forcdincivic
Northeast
30
07-02-2010 07:33 AM
civicRacer95SI
07-30-2003 06:41 PM
Quick Reply: innovate fails again. does anyone have the previous LM2 firmware update?
