Key ignition switch removal?
Old 02-13-2011, 01:49 PM
madcrx69's Avatar
Default Key ignition switch removal?
My key ignition switch is starting to go bad and I want to remove it, but there seems to be no bolts were it hold to the steering colum. Has somebody outthere already changed this? How do I remove the old one?
It's a 1994 civic hatchback 5 speed.
Old 02-13-2011, 02:46 PM
Former User's Avatar
Default Re: Key ignition switch removal?
Do you want to replace the key lock cylinder or the electrical switch?
Old 02-13-2011, 03:18 PM
vitamin_c95's Avatar
i think you have to drill the bolts out, as they are "tamper proof" bolts. I almost attempted this before because my key looks worn
Old 02-13-2011, 04:10 PM
Resident Gearhead
BryanM.'s Avatar
Cut slits into them with a dremel and remove with a screw driver.
http://www.flickr.com/photos/26016203@N03/3396432558/
Old 02-13-2011, 05:32 PM
madcrx69's Avatar
Thanks for the info!!
Old 02-13-2011, 05:36 PM
delsolo95's Avatar
i always wondered this.. thanks x2!
Old 02-13-2011, 05:44 PM
such a genius! I may reignite my desire to do this
Old 02-14-2011, 02:56 AM
Resident Gearhead
BryanM.'s Avatar
You won't need to do that if it's just the switch that's bad.
StraightSlippin
03-04-2013 08:27 AM
dgdarien
10-02-2008 06:24 PM
jaghouse
06-15-2007 12:28 PM
SpoolinEK9
12-06-2005 03:32 PM
lone
12-28-2004 07:40 PM
Quick Reply: Key ignition switch removal?
