Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Acura Integra Type-R
Old 02-11-2011, 11:57 AM   #1
JR_98spec-0315
Default OBD2 scanner cannot communicate with my car. Please Help!
Hi I did a bit of searching and still haven't been able to resolve my issue. I am unable to get my car to communicate with any scanners. I have tried three and all three did not connect. I don't have any check engine lights, but finally got a note for emissions, so in order to pass I will have to get this resolved So any help would be greatly appreciated!
It is a 1998 Integra Type R, the vehicle came with a JDM ecu which was part #
37820-P73-013, will the car only communicate with a USDM ecu?
I've checked the fuse panels under the dash and hood, and they all seem to check out. My only other idea would be to test the obd2 scan port to see if it is getting voltage, does anybody have a diagram of which pins i should test? Thanks in advance!
JR_98spec-0315 is offline   Reply With Quote
Old 02-11-2011, 12:18 PM   #2
MilFhunter001
1998 Acura Integra
MilFhunter001's Avatar
Default Re: OBD2 scanner cannot communicate with my car. Please Help!
That's weird, i'm running on obd 1 and that for sure wont scan at all.
Don't laugh at my car your mom might be in here givin me roadh#@d!
MilFhunter001 is offline   Reply With Quote
Old 02-11-2011, 12:21 PM   #3
JR_98spec-0315
well its got a JDM front so wiring could be a major concern, I'm just hoping that isn't the case, and if by chance anybody would have any experience with this issue . .
Old 02-11-2011, 12:41 PM   #4
racebum
2002 Chevrolet Corvette
racebum's Avatar
Racebum
Send a message via AIM to racebum Send a message via Yahoo to racebum
Originally Posted by JR_98spec-0315 View Post
37820-P73-013, !
is the reason why you're scan tool isn't working
i can't believe this post has went this far without someone telling you what the problem is
jdm ecu's don't use the US scan protocol
Mountain View Carpet Cleaning also found at carpet cleaning beaverton Do you own a turbo honda? see turboinstall.net
racebum is offline   Reply With Quote
Old 02-11-2011, 01:24 PM   #5
2LEM1
I like to party.
1995 Honda Civic
My Garage
2LEM1's Avatar
iTrader Rating: (1)
2lem1
^This
I'm also shocked.
2LEM1 is offline   Reply With Quote
Old 02-11-2011, 01:29 PM   #6
JR_98spec-0315
Thanks for the help, I was worried that was the case, but glad its not a wiring issue as of yet then. Now here's to hoping I can find one at a reasonable price ...
Old 02-11-2011, 01:38 PM   #7
kevinthefawker
kevinthefawker's Avatar
pretty much the jdm ecus run a obd1 interface but has the ecu plugs like the us obd2s, just pop in a us obd2 ecu and you can scan away
kevinthefawker is offline   Reply With Quote
Old 02-11-2011, 01:46 PM   #8
JR_98spec-0315
that makes sense, well at least my fuses are in check then. Any idea on what I'm looking to pay for a USDM ecu? Should it be about the same as a JDM one? I'm hoping i could trade the 003 I have, if at all possible?
Old 02-11-2011, 07:50 PM   #9
racebum
racebum's Avatar
Racebum
what year is your car? like the frame? p73-a02 and a03 are expensive. i sold one of each a year or two ago for $150 and now they are fetching that to $250 pretty easy. a02 is the 97 ecu and a03 is the 98. if you run a a03 in a 96-97 car you'll get a gas tank code
Old 02-12-2011, 05:39 AM   #10
JR_98spec-0315
well its a 98 so I would be looking for the a03, which I am not too sure if I will be able to find in time or at price. .
Do you think it would be possible to use a GSR ecu for a 98 in order to pass emissions, or will that cause more trouble then it would help?
thanks again for all the help!
Old 02-12-2011, 08:53 AM   #11
kevinthefawker
it would be some trouble because the gsr ecu would look for the iab and some other stuff the type R doesnt have hence throwing a code. maybe look for somebody that would loan it out for you if you get them a deposit and return it when you are done.
Old 02-12-2011, 11:51 AM   #12
racebum
racebum's Avatar
Racebum
the iab's won't throw a code, think of the skunk manifold on the gsr. the evap however will. do you still have the factory evap system in place? the gsr ecu would work if you switched it in the parking lot, passed emissions then went back to the itr ecu....might work anyway no idea what tailpipe emissions would do if they both scan and test. i know a lot of states just use the scan tool and send you on the way if there are no codes
Old 02-12-2011, 12:05 PM   #13
wego5typer#431
2013 Ford F-250
My Garage
wego5typer#431's Avatar
There is a usdm 98 type r ecu currently on craigslist(San Francisco bay area).
He is asking $220
2013 Ford F250 Lariat 4x4
2009 Lexus ES350
2001 Integra Type R #01-0431 Turbocharged
wego5typer#431 is offline   Reply With Quote
Old 02-12-2011, 12:30 PM   #14
racebum
racebum's Avatar
Racebum
which means he wants $200, that's a pretty fair deal
Old 02-12-2011, 01:58 PM   #15
JR_98spec-0315
Im in IL here and they only hook up to the scanner as far as I know. Also I am pretty sure all the evap equipment is still in place
Thanks for the heads up on the CL seller emailed him, hopefully he wont think I'm a Nigerian scammer!
Old 02-12-2011, 06:49 PM   #16
DC5yo
DC5yo's Avatar
iTrader Rating: (20)
I wanna say that JDM cars don't even have diagnostic ports. . . but I could be wrong.
JDMTUNERSTORE
WTB: Mugen 15x7 5x114.3 MF10s in singles, pairs of full set.
DC5yo is offline   Reply With Quote
Old 02-13-2011, 04:08 PM   #17
JR_98spec-0315
well its a USDM R and has a diagnostic port, I touched base with the guy off CL he wants to do 250 shipped through ebay. I'll probably end up going with that, just so i can get emissions taken care of and done with. Thanks for all the help, very appreciated!!
Old 02-13-2011, 09:09 PM   #18
racebum
racebum's Avatar
Racebum
still not a bad deal shipped and verified with ebay and paypal, the most you would save if you waited around is probably $75, totally not worth waiting a year plus for a few bucks. the other thing is if this is a03 that's the exact ecu you need for your car. not a year off, not close but exact
you did switch the oil pumps and hook up your cfs sensor when you did the engine swap right? if you didn't you'll have a code for the cfs
Old 02-14-2011, 06:11 PM   #19
Bizarre
Bizarre's Avatar
Just a suggestion, if you're only using this ECU for emissions and to not drive the car very much why not just pick up an LS non vtec ecu? I would assume that they are going to be much cheaper than a "Type R" ecu. Also I'm pretty sure you wont have any codes regardless because the ls ecu has less sensors than the ITR one. I know this worked fine for my OBD1 B16 swap when I was diagnosing some ecu problems. I drove around on an LS computer for 2 days with no codes. Obviously vtec and such wont work but it's not like it matters from an emissions stand point.
Bizarre is offline   Reply With Quote
Old 02-24-2011, 07:27 PM   #20
JR_98spec-0315
received my USDM ecu and passed emissions 5 minutes after i hooked it up! thanks for all the help!
2007, 2285, acura, car, cars, communicate, ecu, find, honda, obd2, obdii, odb, reader, scanner, vehicle
