Honda crv water leak inside?
Old 02-08-2011, 07:56 PM
kc_kc's Avatar
Default Honda crv water leak inside?
i have a 97 honda crv that has been leaking water inside? any idea how to fix it and steps. thanks for your help.s
Old 02-08-2011, 10:02 PM
AP14TW's Avatar
Default Re: Honda crv water leak inside?
Uh, vague much? Where is the leak? ie sunroof, door deals, windshield, rubber seals around door, under dash?
Old 02-10-2011, 08:42 AM
kc_kc's Avatar
It under the passenger seat dash.
Old 02-10-2011, 09:05 AM
Boosted Power's Avatar
Couple different trouble spots. Check to see if the AC dump tube is not clogged. Another, you may have to install a deflector of some sort to deflect water from entering the AC exterior vent/entrance.
It's hard for me to explain, but it's more of a design flaw than anything.
Old 02-10-2011, 05:14 PM
ARMED's Avatar
google 99 crv waterleak, you have to take the cowling off, kinda hard to explain..
had the same problem, its fixed now...
Old 02-10-2011, 07:51 PM
GDD Member
slomofo's Avatar
Is it water or anti-freeze?
Old 02-11-2011, 10:10 PM
qwrty's Avatar
here you go:
http://www.crvownersclub.com/forums/...ght=water+leak
http://www.hondasuv.com/crv/viewtopic.php?t=489
Old 02-12-2011, 02:12 AM
kc_kc's Avatar
thanks very usefully. nice thanks
Old 02-12-2011, 11:09 AM
ALPHA MOVEMENT's Avatar
Nice! Thanks for the help and links! My friend has the same problem.
onidub
Honda Civic (2001 - 2005)
07-24-2010 11:02 AM
BlueIntegraBoy
08-01-2008 09:37 AM
marrieda97accord
07-06-2008 12:06 PM
cmb7684
06-05-2008 06:46 PM
blaisepascal
10-15-2004 10:32 AM
Quick Reply: Honda crv water leak inside?
