Old 01-26-2011, 12:07 PM   #1
redright9
Default sealant for head gasket
So this comming weekend I am hoping to get the cylinder head back onto my civic. What are your thoughts about the spray sealants that are out there.. I have had some people say I should use some of the copper spray stuff.
redright9 is offline   Reply With Quote
Old 01-26-2011, 02:51 PM   #2
skuded
Default Re: sealant for head gasket
if the head isnt being resurfaced, or if it is resurfaced and its not to smooth of a finish, or if you just want to many people use copper spray on headgaskets, it shouldnt hurt anything to use it so go for it, are you having trouble with blown headgasket, cause if you are you will want to have the head resurfaced, most machine shops should be able to resurface it for you for about 30$, if you dont have it done you take the chance of the head being slightly warped and you could still have a leak
skuded is offline   Reply With Quote
Old 01-26-2011, 03:17 PM   #3
Cynical 1
1995 Honda Civic
My Garage
Cynical 1's Avatar
Cynical Motorsport
don't do it, unless you want to do another headgasket after it starts to leak...
Cynical Motorsport
Cynical 1 is offline   Reply With Quote
Old 01-26-2011, 03:48 PM   #4
hellah fresh
dont do it. just get it resurface for 60 and use the gasket. stop cutting corners unless you want to take your heads apart again.
95' Civic Si. (Currently no motor)
93' Mercedes 500SEL
hellah fresh is offline   Reply With Quote
Old 01-26-2011, 04:01 PM   #5
apexi_rsx
Send a message via AIM to apexi_rsx
a head gasket dont cost much just buy one. or your going to be doing this all over again not too far down the road
06 Rsx Type S I/H/E ...14.0@101
97 civic 4dr turbo
apexi_rsx is offline   Reply With Quote
Old 01-26-2011, 06:15 PM   #6
92lxsleeper
1992 Honda Civic
92lxsleeper's Avatar
well when i replaced my headgasket on my d15 a year ago i was a cheap f*** with no money and had a spare y8 headgasket laying around. the block was warped, the head was warped but i replaced the gasket and put it back together anyway. new water pump, thermostat and radiator and its running fine ever since.
My name is Lauren <3 I'm 24.
Real Girls Fix Their Own Cars
My youtube -----> http://www.youtube.com/user/automotiveDIY
92lxsleeper is offline   Reply With Quote
1992, 90, 93, civic, copper, del, gasket, head, headgasket, honda, mercedes, sealant, sol, spray, vs, warped
