Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda Civic (2001 - 2005)
Old 01-25-2011, 03:31 PM   #1
It Wasn't Me
2014 Ubermobil S
Icon6 ► DIY: Radiator Fan Circuit & Fan Switch Circuit Troubleshooting
Before performing any troubleshooting, check the following items:
- Fuses
- Grounds
- Cleanliness and tightness of all connectors
Click the image to open in full size. Click the image to open in full size. Click the image to open in full size.
Radiator Fan Circuit Troubleshooting
1. Check the #4 (20amp) fuse under the hood, and the #14 (10amp) fuse under the dash.
Are the fuses okay?
Yes - Go to step 2
No - Replace the fuse(s) and recheck.
2. Remove the radiator fan relay from the fuse box under the hood, and test it.
Is the relay okay?
Yes - Go to step 3
No - Replace the radiator fan relay.
3. Measure the voltage between the #1 terminal of the radiator fan relay 4-pin socket and a body ground.
Is there battery voltage?
Yes - Go to step 4
No - Replace the under-hood fuse/relay box.
4. Using a jumper wire, connect the #1 and #2 terminals of the radiator fan relay 4-pin socket.
Does the radiator fan run?
Yes - Go to step 5
No - Go to step 6
5. Disconnect the jumper wire, and turn the ignition switch ON (II). Check for voltage between the #3 terminal of the radiator fan relay 4-pin socket and a body ground.
Yes - Go to step 9
No - Check for an open in the wire between the under-hood fuse/relay box and the under-dash fuse/relay box.
6. Disconnect the radiator fan motor 2-pin connector.
7. Check for continuity between the #2 terminal of the radiator fan relay 4-pin socket and the #2 terminal of the radiator fan motor 2-pin connector.
Is there continuity?
Yes - Go to step 8
No - Repair an open in the wire between the under-hood fuse/relay box and the radiator fan motor 2-pin connector terminal #2.
8. Check for continuity between the #1 terminal of the radiator fan motor 2-pin connector and a body ground.
Yes - Replace the radiator fan motor.
No - Check for an open in the wire between radiator fan motor 2-pin connector terminal #1 and a body ground. If the wire is okay, check for a poor ground at G201.
9. Reinstall the radiator fan relay.
10. Disconnect the radiator fan switch 2-pin connector. Jump terminals #1 and #2 to see if the fan runs.
Yes - Replace the radiator fan switch.
No - Go to step 11
11. Remove the jumper wire, and measure the voltage between the #2 terminal of the radiator fan switch 2-pin connector and a body ground.
Yes - Check for an open in the wire between radiator fan switch 2-pin connector terminal #1 and body ground. If the wire is okay, check for a poor ground at G101.
No - Repair an open in the wire between the radiator fan switch terminal #2 and the fuse/relay box under the hood.
It Wasn't Me is offline   Reply With Quote
Old 01-25-2011, 03:36 PM   #2
It Wasn't Me
2014 Ubermobil S
Default Re: ► DIY: Radiator Fan & Fan Switch Circuit Troubleshooting
Radiator Fan Switch Circuit Troubleshooting (Open)
1. Disconnect the radiator fan switch 2-pin connector.
2. Turn the ignition ON (II).
3. Measure voltage between the #2 terminal of the radiator fan switch 2-pin connector and a body ground.
Yes - Go to step 4
No - Repair an open in the wire between the radiator fan switch 2-pin connector and the fuse/relay box under the hood.
4. Turn the ignition OFF, and check for continuity between the #1 terminal of the radiator fan switch 2-pin connector and a body ground.
No - Check for an open in the wire between the radiator fan switch 2-pin connector terminal #1 and body ground. If the wire is okay, check for a poor ground at G101.
Old 01-25-2011, 03:43 PM   #3
It Wasn't Me
2014 Ubermobil S
Radiator Fan Switch Circuit Troubleshooting (Short)
1. Remove the radiator fan relay from the fuse/relay box under the hood.
Is the relay okay?
Yes - Go to step 2
2. Remove the radiator fan switch and test it.*
Is the radiator fan switch okay?
Yes - Go to step 3
No - Replace the radiator fan switch.
3. Disconnect the negative cable from the battery.
4. Disconnect ECM / PCM connector B (24-pin) and the under-hood fuse/relay box 14-pin connector.
5. Check for continuity between the #2 terminal of the radiator fan switch 2-pin connector and a body ground.
Yes - Repair a short in the wire between the radiator fan switch 2-pin connector terminal #2 and the under-hood fuse/relay box.
Testing the Radiator Fan Switch: Link
Old 07-05-2012, 04:22 AM   #4
ChrisMaconGa
Can I use this also for a 1990 Civic sedan in trouble shooting the fans?
Chris Brooks - Macon Ga.
ChrisMaconGa is offline   Reply With Quote
Old 07-22-2012, 12:49 PM   #5
THE2003CRV
Default Re: ► DIY: Radiator Fan Circuit & Fan Switch Circuit Troubleshooting
I am trying to find the fan switch 2-pin connector shown but do not see it - - am I looking in the wrong place? Is it close to the fuse block? The relays are ok, and I found the fan motor connector. Honda CRV 2003 4-door
Thanks in advance
THE2003CRV is offline   Reply With Quote
Old 07-22-2012, 02:45 PM   #6
toyomatt84
Sanji
toyomatt84's Avatar
iTrader Rating: (1)
Send a message via AIM to toyomatt84
Thanks in advance
You're in the wrong forum.
*free hugs*
My For Sale Thread
toyomatt84 is offline   Reply With Quote
Old 10-16-2012, 06:31 PM   #7
dc97
Yes - Go to step 9
I have a 97 Integra hence my username..
On my DVOM it shows -0 voltage so meaning theres no voltage going on..
on my schematics it shows a black/yellow wire that goes to the underdash fuse box to fuse #13 (cooling/heater fan relay fuse)
Fuse is good, but i get no power when i hit it with a test light..
Anybody know where the black/yellow wire specifically is by the fuse box (underdash)?
(tired of the bypass that was done by the previous owner and i want my fan running right... running way too rich and not hitting normal temperature + dumping a bunch of fuel)
Thanks.
dc97 is offline   Reply With Quote
Old 10-20-2012, 08:51 AM   #8
Wahabbaluch
Excellent trouble shooting tips. After carring out all above checks, finally came to a faulty fan. When it was opened, the fault found in carbon brushes, those were found worn. It is advised that before replacing a faulty fan, its carbon brushes must be checked.
Wahabbaluch is offline   Reply With Quote
Old 04-28-2013, 05:51 PM   #9
jald3rd
1997 Honda Civic
i follow all the steps (check all the fuses and relays, fan working with the jumper, replace the thermostat and fan switch) but the fan still not working when the needle is on H already. I put the jumper back and the fan works and the temperature went down. where else do you think i need to check? thanks
jald3rd is offline   Reply With Quote
Old 12-25-2013, 01:35 PM   #10
Nandasmo
Nandasmo's Avatar
Thanks for this troubleshooting guide.
Nandasmo is offline   Reply With Quote
block, civic, connector, disconnect, diy, fan, harness, honda, radiator, relay, switch, testing, wires
