| Welcome to Honda-Tech! | ||
#1 |
Hello all, I am having some problems with my CRV. I just replaced a cracked valve, the timing belt, the head gaskets, and some seals on my crv. Now I is still throwing error codes saying all 4 cylinders are misfiring and I is giving me the errror code p1399pd this code is not in the chilton manual please help. Thank you!!!
#2 |
Have you driven the car since the work was completed? How does it run?
http://www.PDM-Racing.com |
#3 |
It does not run smooth, it occasionally bucks. Does not Idle steady either. Thanks for the reply I hope that helps...
#4 |
1399 is a general misfire code. i would take it back to the shop and have them check everything again. timing might be off, they may not have adjusted the valves. to me, with all that work they must have left something loose or something.
genesis automotive - injen - jlb motorsports - frank's fab shop - options auto current: '00 ap1 & '98 ej8 ---- '07 fg1 = totaled ---- '94 accord = sold |
| Tags |
| 1399, 2000, 2002, 2011, 4cylinders, accord, code, codes, cracked, crv, dtc, error, honda, misfire, valve |
