1996 Honda Accord lx Turbo
Old 01-19-2011, 07:31 PM
Vito5790's Avatar
Default 1996 Honda Accord lx Turbo
I plan on making a minimum of 400whp
Here's what i got so far:
F22b2 (non vtec)
Ported and polished head and plenum
Arias 9:1 86mm
Rods form Bisimoto
Pro valve springs and retainers also from Bisimoto
RC 750cc injectors
Fidanza 8lb flywheel w/replaceable clutch surface
ACT clutch
King bearings
Still to come:
Stage 2.4 cam and cam gear from Bisimoto
AEM fuel/ignition controller
KOYORAD radiator w/53mm core
Stainless or titanium valves
Wallbro 255
Limited slip kit from phantom grip
As far as the turbo setup goes, I don't have a plan yet so I'm open to suggestions
What do you think about the looks of this one? The bumper and headlights will be like ones in this pic but every thing else will probably be different.
Old 01-20-2011, 04:45 AM
nus_dogg's Avatar
Default Re: 1996 Honda Accord lx Turbo
Sounds like a legit setup bruh. Keep us posted!
Old 01-20-2011, 07:05 AM
19Accord97's Avatar
Nice! Can't wait to see it done :D
Old 01-20-2011, 06:33 PM
Vito5790's Avatar
Thanks! I can't wait to get it done my self! lol Unfortunately my budget is slowing me down...
Old 01-20-2011, 06:37 PM
Vito5790's Avatar
Is importperformanceparts.net a legit site? Just wondering because i was looking through it and found quiet a few parts i would like to get from them.
Old 01-20-2011, 06:47 PM
19Accord97's Avatar
No idea. I have used horsepowerfreaks.com before and they are awesome. They run monthly specials usually if youre on their e-mail list.
Old 02-10-2011, 05:47 PM
Vito5790's Avatar
Toga high volume oil pump finally came in. Really glad i found one. Almost gave up on looking for one.
Old 02-10-2011, 05:58 PM
wolfy47's Avatar
nevermind....i had a silly question
cant wait to see it when its finished
Old 02-10-2011, 06:13 PM
Vito5790's Avatar
I tried posting some pics but couldn't figure out how.
Old 02-10-2011, 09:57 PM
MM Gruppe B
MAD_MIKE's Avatar
If you scroll down to Manage Attachments you can upload a picture from your files, or upload/hotlink the picture if its on a website via the address.
Old 02-11-2011, 06:07 AM
Vito5790's Avatar
Some pics of the parts i got so far.
And Mike, thanks.
Old 02-11-2011, 06:21 AM
nus_dogg's Avatar
Nice.
Old 02-11-2011, 01:22 PM
Vito5790's Avatar
Does anyone know where i can get an aftermarcket intake and throtle body that will work with f22b2
Old 02-18-2011, 05:14 PM
Vito5790's Avatar
Finally got bottom end put together and block painted
Old 02-18-2011, 08:19 PM
HonBeer's Avatar
Why on earth would you paint the block?? Paint hinders cooling. And it looks shitty also.
Old 02-19-2011, 05:20 PM
Java^FiT's Avatar
oh man, your plan kind of makes me wish i diddnt sell my 97 lx
Old 02-19-2011, 06:37 PM
Vito5790's Avatar
Thanks man. But there's lots of other plans out there that are better then my
Old 02-19-2011, 06:57 PM
GhostAccord's Avatar
Looking good! keep'er going.
Just out of curiosity what is the volume that HV oil pump is rated for?
Old 02-20-2011, 01:32 PM
Vito5790's Avatar
That i don't know. All i know is that its more than stock and the only 1 i could find. I got it from importperformanceparts.net
Old 02-22-2011, 08:31 PM
Vito5790's Avatar
I had to put stock valves in just so i can drive it at least till i save up some money for the rest of the parts.
Old 02-23-2011, 04:24 AM
bigsnorlax's Avatar
Looking very good so far! Ignore the haters... i like painted blocks ha.
Do you know what route your going as for as an EMS or tune?
And what turbo are you thinking about running?
Looking good though man, looks solid, and not everyone else's slopped together F turbo "build."
Old 02-24-2011, 09:51 AM
Andryzzle's Avatar
Venom used to make an IM if you can find one (look for the Acura CL). The f23 IM is an oem upgrade you can pursue also. There is a little custom work for the f23, but less than other options.
Old 02-24-2011, 01:57 PM
Vito5790's Avatar
Thanks Guys!
As far as ems goes i plan on getting a fuel/ignition controller from AEM. Its kinda like a pigieback for the factory ems. You can run injectors straight from it or it can control them through the ems. I looked at the install instructions and it interupts the inputs from the crank, cam, map and tps scensors and it uses them for maping or modifies those inputs which are then sent to the ems. Thats how i understand that, may be different though. As far as turbo goes, I will get one of those cheep ones from ebay first. and when i save up enough money i will upgrade to ether a turbonetics or garret or maybe even something else.
Old 02-28-2011, 12:27 PM
accord_raffi's Avatar
You should just get your car tuned with software and ditch the piggyback. It's going to use the input from those sensors to increase fuel, but then you're going to end up with huge timing issues and everything's going to go boom. Go to a tuner.
Old 02-28-2011, 12:30 PM
You can skip on the LSD if you're short on cash and put that towards a tune. What kind of power are you looking to make? I was going to say go with a t3/t04e 57 trim until I saw you had some beefy engine mods planned. Ask your tuner once you find him.
Quick Reply: 1996 Honda Accord lx Turbo
