| Welcome to Honda-Tech! | ||
#1 |
hi fellas
first off, i pulled fuel line im getting fuel . it will crank but wont start while i crank it , my dad checked the spark, with 1# cylinder wire, no spark at all. i replaced the ingnition coil, still not starting and no spark, im guessinng is the ingnition modual? how do you take it apart? can any one post me a link of a repair manual? the modual screws is all the way in side the dizzzzy the car is all stock, never had any issue, besides sometimes when you drive to get gas or to a store, it would start and die. while it dies if you give it gas you will get no reaction, let it chill for a few mins it will start and go. this happens usally after driving it then start it within few mins. any input would be really appreciated thanks guys
EG6 !! |
#2 | |
if not go and buy each plug wire's and give us an update
DONT FOLLOW ME YOU WONT MAKE IT |
#3 |
the wires would be the last thing i would look tho, they could be bad, but in one night and no one touch them? i doubt it
can some one please tell me how to take off the ICM? there is a aloy plate that covers the screws of ICM, also inorder to take of the aloy plate there is a piece of rubber thing behind the rotor, it gets on the way when i tried to take of the plate to get to the screws
EG6 !! |
#4 |
Moderator
2000 Honda CivicMy Garage |
What year/engine?
Have you checked whether the timing belt has snapped or stripped? Does the Blk/Yel wire inside the distributor get voltage?
Don't guess, troubleshoot --------------------------------------------------------- Useful tech links: FAQs; Codes; Check Spark; Test Fuses; Fuse 15 TSB; Clean IACV or FITV --------------------------------------------------------- Please don't PM me tech questions. Create a thread. |
#5 |
its a 1.5 non vtec, 93 civic hatchback
timing belt is good, cuz when i took off the rotor i had to rotate the motor, so i put it in gear pushed the car, the dizzzy rotor would rotate when i do that. but i will double check of the timing belt snapped its not the coil for sure, i just put in a new one. how do you take off the ICM? funny thing is ,i have a multimeter, no one here can teach me how to use a multimeter, i bought a ICM i dont know how to take the old one out i be working on it first thing in the morning tomorrow, i hope you guys can give me some tips
EG6 !! |
#6 |
Moderator
92-95 Civic with stock D15b7? Realize that a bad igniter unit is but one of several possible causes of no spark.
![]() Does the distributor get voltage?
#7 |
i found that first pdf from manual i cant understand how they take off the ICM. is the ICM held by 3 bolts or 2. i bought both of them and a coil
EG6 !! |
#8 |
fixed , new ICM and cleaned IACV
EG6 !! |
| Tags |
| 93, 95, american, civic, cleaned, crank, hatch, hatchback, honda, moduals, motor, spark, start, website, wont |
