how can i get louder turbo sound
Old 01-15-2011, 07:47 AM
TURKISHFORCE's Avatar
Default how can i get louder turbo sound
hi from germany.
can i make anyway my gt30 (no-name) sound louder with likes turbo diesel ore this video http://www.youtube.com/watch?v=pvI58...eature=related
i heard i need a highflow casing???
ore a hole in the boost syteme (JOKE) ore when turbo scoop is damage
ore ebay turbo whistler ):(:
anny idea?
mfg Sultan
ee9 turbo/ef9 turbo
Old 01-15-2011, 08:02 AM
Crazy_SI_T's Avatar
Default Re: how can i get louder turbo sound
i got a holset and its LOUD once it takes off
Old 01-15-2011, 09:14 AM
93lsv_turbo's Avatar
my bullseye 57 trim is loud as hail but my exhaust ends right before my fire wall
Old 01-15-2011, 12:20 PM
hybrdthry911's Avatar
buy a real gt3076r.
Old 01-15-2011, 12:50 PM
96 GSR-T's Avatar
^^^^ What he said lol... 30R's are really loud IMO.
Another way is to run your wastegate dump (if you have one) into the downpipe at the sacrafice of some power.
Old 01-15-2011, 01:39 PM
LightningTeg's Avatar
The inducer bleed groove is what makes that whistling
Old 01-15-2011, 01:44 PM
Axix24's Avatar
a 30r is pretty loud as it is when spooling up... you can hear the turbo spool alot louder than a 35/37r...
Another thing you could so is run a mic next to your turbo and run speakers on the outside of your car so you can amplify the turbo spool so everything can know you got a turbo.. You might as well run a mic to the bov so you can hear a loud pshhhhhhhhhh noise when you let off the throttle in between shifts..
Old 01-15-2011, 02:06 PM
CanadianEF9's Avatar
get one of these
http://cgi.ebay.com/ebaymotors/Exhau...Q5fAccessories
Old 01-15-2011, 05:41 PM
Sordz's Avatar
no muffler on your exhaust.
Old 01-15-2011, 06:22 PM
viper_boy403's Avatar
The turbo sound is going to be partially dependent on your intake setup. No filter, like in the video, will be louder than running an intake tube and filter
Old 01-15-2011, 06:44 PM
30psi_gst's Avatar
Re-route your wastegate back into your exhaust.
Old 01-15-2011, 06:52 PM
sanman000719's Avatar
would this be considered a ricer ? lol
Old 01-15-2011, 07:12 PM
ashb82's Avatar
http://www.expotv.com/videos/reviews...-01000-1/29247
put this in front of your turbo
Old 01-15-2011, 07:36 PM
Stopsign32v's Avatar
Not unless he runs no filter and no muffler.
Old 01-15-2011, 09:10 PM
SovXietday's Avatar
Turn up the boost, duh.
Old 01-15-2011, 09:12 PM
30psi_gst's Avatar
Looks like im a ricer.
Old 01-16-2011, 12:17 AM
i have long time test witout a air filter on the turbocharger and result ist the same (no turbo sound)
my wastegate is normal going to the back into the exhaust systeme.
and a run still the car with a 3 zoll exhaust syteme and no g-kat ?
i buy a neu turbocharger with high flow casing like garrett ore turbonetics.
ore change my casing site of the turbo and install a high flow ?
Old 01-16-2011, 12:27 AM
Tony the Tiger's Avatar
Slot and port your compressor cover and modify it to become an anti-surge housing. You can drill holes like some housings, or T04Z/HKS T51R style inlet.
Cut the slot at the tip of the compressor exducer, and start with the narrowest slot (high pitch), and keep widening it until you get the lower note. If you widen the slot too much and the wheel doesn't deliver enough air velocity, then you lose the sound again and it will become a low note woosh.
Old 01-16-2011, 06:36 AM
ashb82's Avatar
i have noticed the better my car is tuned the more hp the better it runs the less the turbo sound is. My first build sounded like a jet, i had no exhaust, no tune stock ecu (because i was a dumb *** in 2000), boost leaks on ever pipe then the engine blew. I built the engine same turbo tuned with afc still sounded like a jet. As i learned more and more about turbos and tuning the sound has went away. Still got the same turbo used it on 4 builds and its on my car now it is quite barely notice its turboed. It is a 57 trim turbonetics got to be the most reliable turbo i ever owned. By the way have the same turbo as the video on a car and its not even loud.
Old 01-16-2011, 06:49 AM
stopsign32 you know what man first off i dont have a street worrior no filter and no muff means more power if you didnt know that now you do.
the loud whistling sound of a turbo doesnt do anything for performance, but it make you look good infront of your friends wich would lead me to beleive its not about performance but more the impression. as long as the boost gage reads what you have it set at the sound of he turbo isnt an issue.
you have issues with me then pm me
Old 01-16-2011, 06:50 AM
correct the same thing i have noticed as well.
Old 01-16-2011, 07:17 AM
rat city rex's Avatar
X2
Or run a Holset turbo and take the surge ring out. It will make it scream....... looks like that's what they did in the video you posted.
Old 01-16-2011, 07:43 AM
Turbo-LS's Avatar
true if engine is running effecient the turbo wont be as loud less backpressure on the compressor from good flowing engine. when i went from ls head to vtec head the same turbo i can barely hear it now
Old 01-16-2011, 07:48 AM
mine is barely audible, and i can hardly hear my waste gate through the dump either
Old 01-16-2011, 09:22 AM
alperx's Avatar
good choice.
Originally Posted by hybrdthry911
buy a real gt3076r.
Quick Reply: how can i get louder turbo sound
