Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda Accord & Crosstour (2003 - Current)
Old 01-13-2011, 04:24 AM   #1
MrsR
Default Squealing noise
I am trying to see if anyone knows what is going on with my car. I have a 2004 Honda Accord and just recently, I started hearing this light squealing noise coming from my engine area. It sounds very loud from inside the car, but I canít really hear it standing outside the car. It only comes when I am idling, as soon as I press the gas, it stops. It does not seem to be causing any problems to the way my car drives, the sound is just really annoying and I would like to know what it is so I can get it fixed. I already had the main belt replaced, and that did not help at all. Does anyone else have this problem?
MrsR is offline   Reply With Quote
Old 01-13-2011, 05:01 AM   #2
andyz
Default Re: Squealing noise
Still sounds like a belt problem. Use a little belt dressing or adjust the belt tension. Sometimes a glazed belt refuses to settle down. New belt.
check:
alternator belt
power steering belt
air conditioning belt
andyz is offline   Reply With Quote
Old 01-13-2011, 07:08 AM   #3
redbull-1
redbull-1's Avatar
Originally Posted by MrsR View Post
I am trying to see if anyone knows what is going on with my car. I have a 2004 Honda Accord and just recently, I started hearing this light squealing noise coming from my engine area. It sounds very loud from inside the car, but I can’t really hear it standing outside the car. It only comes when I am idling, as soon as I press the gas, it stops. It does not seem to be causing any problems to the way my car drives, the sound is just really annoying and I would like to know what it is so I can get it fixed. I already had the main belt replaced, and that did not help at all. Does anyone else have this problem?
1. Was the replacement belt a Honda OEM or aftermaket?
2. If the noise is coming from the belt area, it may be the belt if your are not using Honda OEM or a quality aftermarket belt. Or my guess would be the auto-tensioner. The attach image is the auto-tensioner for a 4 cylinder (for the 6 cylinder, slightly different part). It may just be the idler pulley (#5) needing replacement or the whole tensioner assembly (#5). The whole assembly isn't that much more than just the idler pulley.
Btw: Is this a 4 cylinder or 6 cylinder?
check:
alternator belt
power steering belt
The 7th and 8th gen Accords use a single drive belt for A/C compressor, alternator, power steering pump, and water pump.
Generally, it is best to avoid belt dressing. It'll quiet the squeal for a day or two by making the rubber gummier. The squeal will come back and there still will be gummy belt dressing on parts of the engine.
redbull-1 is offline   Reply With Quote
Old 01-13-2011, 07:52 AM   #4
h2bek
h2bek's Avatar
check:
alternator belt
power steering belt
x2
**ill Garage**
4dr ek daily beater 400+hp club
h2bek is offline   Reply With Quote
Old 01-13-2011, 06:44 PM   #5
Phosho
Still learning as a noob, but I read that accords have noise canceling projectors that should cancel out the noise. If it is a loud squealing noise, it may not be the problem but could be. Feel free to correct me cause i maybe wrong.
Phosho is offline   Reply With Quote
Old 01-13-2011, 07:28 PM   #6
redbull-1
redbull-1's Avatar
Only 7th generation Accord Hybrids had Active Noise Control (ANC), later the 8th generation Accords (2008 - 2011) incorporated Active Noise Control (ANC), you can read about it in these two links:
http://www.honda.com/newsandviews/ar...=2004091736965
http://www.honda.com/newsandviews/article.aspx?id=4107
As it states, "ANC significantly reduces certain low-frequency sounds in the interior. "
Old 01-13-2011, 09:45 PM   #7
Phosho
Yea i thought i read something along those lines. Sorry for the misinfo and thanks for the correction.
Old 01-14-2011, 08:31 PM   #8
mastermeat
mastermeat's Avatar
I had the same problem when it was cold. You don't think you here it when you drive but it's there. There is a technical bulletin about replacing a smaller o-washer on the power steering pump that gets dried out and allows air to escape hence the "squeal". The Tech said the o-washer usually fixes the problem 99% of the time. I thought there was a sticky on this somewhere.
I had the dealer fix it and they took 20 mins and charged me $32. The part was $1.35...
mastermeat is offline   Reply With Quote
Old 01-14-2011, 10:50 PM   #9
redbull-1
redbull-1's Avatar
The TSB is for the power steering "moans or whines" when the engine is cold. The noise usually goes away when the engine warms up.
http://ww2.justanswer.com/uploads/ac...63906_moan.pdf
The OP states the "squeal" is when idling and stops when the gas is pressed, so it may be a different problem.
Old 01-14-2011, 11:09 PM   #10
Donalds
Donalds's Avatar
Is there any difference in the belt of model 2004 and 2005 ??
I want to change the belt but the one i purchased is not properly fitting .
[url=http://www.twincitiesautoservice.com/oil-change-minneapolis]oil change minneapolis[/url]
Donalds is offline   Reply With Quote
Old 01-19-2011, 07:04 AM   #11
cvega8233
I have the same problem. The wining noise usually only happens on a cold start. I have figured out that it is coming from the powerstering motor, so it is probably a belt problem.
cvega8233 is offline   Reply With Quote
Old 01-19-2011, 05:21 PM   #12
BLKFLSH
BLKFLSH's Avatar
Click on this link. It sounds like your problem.
92 accord EX sedan : sold after 12 great years
03 accord EXV6 sedan: smooth as silk
BLKFLSH is online now   Reply With Quote
Old 01-20-2011, 04:06 PM   #13
Kev2010
Kev2010's Avatar
Yeah you should change you're belt.
Kev2010 is offline   Reply With Quote
Old 03-04-2011, 11:29 AM   #14
whtguy1678
I have the same issue on my '03 Accord LX 4cyl. It's not a belt noise, no question. I thought the power steering pump might going out at first, but there is no noise at all when steering and I have never heard any typical whinig noises from the pump or on start up. It is most definitely the idler pulley (IMO). The noise I hear is a very soft, but very high pitched sound of rubbing metal. It's as if the pulley is slightly misaligned and is rubbing. If I look closely at the pulley on my car, I can see the belt move from side to side. It is hardly noticeable, unless you know what to look for. I would start with replacing the idler pulley or auto-tensioner assembly and see where that gets you.
whtguy1678 is offline   Reply With Quote
Old 04-28-2013, 02:55 PM   #15
accordlife92
Please help me ! 1999 accord coupe v6 squealing noise i just changed my upper radiator hoes 10 secs after it started . if anybody has any clue comment here's the video of my actual car making the noise http://www.youtube.com/watch?v=pDZdR...ature=youtu.be thanks !
accordlife92 is offline   Reply With Quote
Old 08-23-2013, 08:41 PM   #16
956api
When i turn on my 90 accord it skeaks new belt by the way an even louder when i turn on my a/c how can i stop the noise help
956api is offline   Reply With Quote
Old 08-24-2013, 06:37 AM   #17
Lost Again
First, you might want to post in the correct section.....
Tighten the belt(s).
My child arrived just the other day; he came to the world in the usual way
I can explian it to you, I CANNOT understand it for you
Lost Again is offline   Reply With Quote
2004, 7th, 97, accord, air, belt, civic, cold, conditioner, generation, glazed, honda, loud, noise, replacement, squealing, taurus, tensioner
Similar Threads
Rebuild. Engine squeal?? Help Jorgeb94 Honda Civic/Del Sol (1992 - 2000) 22 04-28-2014 07:28 PM
D16z6 Squealing noise coming from crank pulley area marylandeg Honda Civic/Del Sol (1992 - 2000) 6 06-23-2013 11:32 AM
New Problem! 06mmDc5 Acura RSX DC5 & Honda Civic EP3 11 06-17-2013 06:50 AM
Loud Squealing noise when cranking 92 civic cx hatch jdmperez Honda Civic/Del Sol (1992 - 2000) 5 03-13-2013 02:15 PM
Wilwood brake pads Ash J. Williams Suspension & Brakes 4 09-26-2012 06:23 AM
