Signs of a broken or blown shock or strut???
Old 09-24-2002, 06:19 AM
Kalokohan's Avatar
Default Signs of a broken or blown shock or strut???
What are the signs of a busted or broken shock besides leaking??
Noises I should listen for? Performance issues I should watch out for?
[Modified by Guardson3r3, 10:25 AM 9/24/2002]
Old 09-24-2002, 06:32 AM
CovertFI's Avatar
Default Re: Signs of a broken or blown shock or strut??? (Guardson3r3)
just push your car upand down by hand and if the side you suspect bounces more than the other 3 corners of your car then the shock / strut is bad
Old 09-24-2002, 06:40 AM
BERT-O's Avatar
look for leaks as well.
usually around the cylinder bore.
Old 09-24-2002, 08:08 AM
CXHatchback's Avatar
Default Re: Signs of a broken or blown shock or strut??? (SANBST)
also look for a puddle of oil in your garage underneath the shock assmebly if it blew out right away.
Also the worst ride quality you can imagine.
Old 09-24-2002, 08:31 AM
vtec69's Avatar
your ride will be very bouncy
Old 09-24-2002, 09:21 AM
Max_ED9's Avatar
Default Re: Signs of a broken or blown shock or strut??? (vtec69)
when i lowered my crx 3+ inches when i first got my Ground controls... my stocks shocks had ALL blown the oil all over the wheelwells everywhere! it sucks...
how do you tell if gas shocks are blown?
Old 09-24-2002, 09:33 AM
Traymack1's Avatar
Default Re: Signs of a broken or blown shock or strut??? (maxracing)
my back shocks make a creaking noise when i push down on the back of the car, does that mean they are bad? '93 civ si, original shocks. Also the ride is not bouncy but when i have weight in the back they seem to fade.
Old 09-24-2002, 09:41 AM
Kalokohan's Avatar
Default Re: Signs of a broken or blown shock or strut??? (CovertFI)
I'll try all those things to see if they are blown. Also, how important are the bump stops on the shocks?
96WhiteOnBlack
03-19-2007 09:09 PM
David123
01-30-2006 09:28 PM
HapiHonda
11-16-2002 07:48 AM
Gennady
02-22-2002 11:35 AM
d0nkeyxPunch
08-07-2001 07:26 AM
Quick Reply: Signs of a broken or blown shock or strut???
