Old 01-12-2011, 07:39 AM   #1
ToTriggerHappy
1998 Honda Civic
ToTriggerHappy's Avatar
Default **Timing a b18c1 with no timing cover**
How would i go about timing my b18c1 with no upper or lower timing cover?
'98 Civic LX B18C1 swap!
Check out my mini-me swap: http://honda-tech.com/showthread.php?t=2724719
ToTriggerHappy is offline   Reply With Quote
Old 01-12-2011, 08:56 AM   #2
JDM-sol 89
JDM-sol 89's Avatar
Pine It2
Default Re: **Timing a b18c1 with no timing cover**
Turn your crank, by hand or socket while your plugs out, until the outside two pistons are all the way up (cylinder 1 and 4). Then on your cams, line the two little marks so they're facing each other and the arrows are pointing up.
~Master Debator~
You think that JDM tow hook looks sick until you catch your shin on it.
JDM-sol 89 is offline   Reply With Quote
Old 01-12-2011, 09:01 AM   #3
apexi_rsx
Send a message via AIM to apexi_rsx
usally on the oilpump there is a mark to line the crank key up to then time the top. the cams have a fish eye above the cams ( by the cam gears) u can lock the cams with a drill bit or a 10mm bolt.
06 Rsx Type S I/H/E ...14.0@101
97 civic 4dr turbo
apexi_rsx is offline   Reply With Quote
Old 01-12-2011, 11:52 AM   #4
ToTriggerHappy
1998 Honda Civic
i mean using a timing light and turning the distributor. I know on my D series they have a mark on the bottom timing cover and three marks on the harmonic balancer.
Old 01-12-2011, 04:27 PM   #5
ToTriggerHappy
1998 Honda Civic
bump
Old 01-12-2011, 05:38 PM   #6
ToTriggerHappy
1998 Honda Civic
bump
Old 01-12-2011, 06:26 PM   #7
92civlude
Does your pulley have timing marks? Remove the crank pulley and set to TDC on the timing belt pulley and the arrow cast into the oil pump. Put the crank pulley back on, But dont tighten it. Try to make a reference mark on the block and line it up with the white "T" on the crank pulley. Tighten the crank pulley. Now at least youll have a 0 degree reference. You should be able to get it close with an adjustable timing light. Set the timing light to the timing spec. and check timing by lining up the marks on the pulley and the mark you made. Good luck.
92 Civic Hatch G23 DOHC VTEC turbo
92civlude is offline   Reply With Quote
Old 01-12-2011, 08:21 PM   #8
ToTriggerHappy
1998 Honda Civic
sounds like alot of **** to time my engine. lol
Old 01-13-2011, 06:31 AM   #9
92civlude
HA! Its either that or get some covers!
b18c1, belt, checking, civic, cover, crank, ha, mark, marks, oil, pulley, pump, rsx, set, timing, timming
