Tachometer test signal?
Old 01-01-2011, 01:21 PM
jwriter's Avatar
Default Tachometer test signal?
Hello this is for a 2001 Civic. This is kind of a technical question, but I need to know what the pulse train at the tachometer test connector looks like. In other words, what is the pulse voltage, pulse rate and pulse width, that kind of thing. My car currently doesn't have an engine, or I would just look at the signal with an oscilloscope. Probably not too many people know this but I thought I would give it a try - can anybody help?
Old 01-01-2011, 04:53 PM
lazlong's Avatar
Default Re: Tachometer test signal?
It pulses from 0v to around 5v. Width of the pulse depends on the vehicle speed.
Old 01-01-2011, 08:19 PM
jwriter's Avatar
Thank you! I assume you mean engine speed. In other words, at 0 rpm the width of the pulse is vary narrow and at 6000 rpm it is much wider?
Old 01-02-2011, 04:39 PM
fiveten's Avatar
The tach is driven by the pcm through serial communication. There is no tach pulse to measure. You can tap into the communication line with your dso and get a serial pattern but you wont know what it is saying.
Old 01-03-2011, 02:05 AM
lazlong's Avatar
Guess I should have been more specific. The VSS signal pulses from 0v- 5v.
Old 12-31-2013, 10:48 AM
gabrielsousa's Avatar
can you tell me how we do the wiring ?
MIEj1
05-15-2012 02:39 PM
purplecivicturbo
Engine Management and Tuning
10-08-2010 02:42 PM
prelude_93vtec
06-28-2007 03:00 PM
fmfkid250
01-06-2007 01:12 PM
nighttime
10-26-2002 02:21 PM
Quick Reply: Tachometer test signal?
