led cluster bulbs...
... what size bulbs do i order from superbrightleds.com for the 3 cluster lights on my 97 ls? specific links would be great. :]
Nate.
Nate.
Re: led cluster bulbs...
i used T10 wedge LED bulbs from eBay on my EF sedan and 00 Durango. But I've never seen a DC cluster. But you'll get the idea.
http://shop.ebay.com/?_from=R40&_trk...All-Categories
Where you able to plug them right into where the oem bulbs where and that was all you had to do? Then they worked? I have a 91 Integra and would like to get some too. Which bulbs would I need?
(i didn't replace those (T5) ) heres some pics of the differences.
i don't really know if this cluster is from a DA or DC. is just for example. it should be from a DC. (VSS).
RED= T10
YELLOW= T5
PURPLE= unknown
the difference
T10 LED-----T5 OEM-----T10 OEM
No that's just the back of the cluster itself. On a DC it's 2 screws to remove the trim piece and 3 screws to remove the cluster.
The stock bulbs for illumination are actually 194 or 168 wedge bulbs (same size). I don't know about that T10 designation. Never heard of that.
i'm pretty sure that they will fit the DA, i didn't use any resistor i just replaced them as they were OEM. i have LED all around my car (signal l, stop l, side markers l,dome lights. license plate, reverse l, etc.) is not ricy at all it just improves visibility to me. oh and i have more than a year with them. ill post some pics later on.
What LED's are you using for signals and brake lights? In my experience direct-fit replacement LED's are dimmer than normal incandescent bulbs in all situations.
this pic looks kind of red cuz i put my finger on the camera flash.
this is my interior u can see is the dome light and not my camera flash by looking at the shadows.
i'm thinking of doing a write up on this. which section would i have to post it on?. i have an spare cluster and the LEDs are not that expensive.. if i do it ill post step by step and lots of pics.
for the brakes i used the AutoZone ones and for the signal and reverse lights i think i used the 1156 (white). they work fine for me.
Awesome thread which will help you
https://honda-tech.com/forums/acura-integra-6/diy-led-xenon-bulbs-every-bulb-type-listed-cluster-climate-control-exterior-interior-2343038/
Correct on the 194/168 bulbs for the red circled ones, the bulbs pop out of the little plastic plug. No resistors are needed for the cluster or climate control. Depending on which LED's you get, brightness will vary. Quite often turn signals require a resistor to prevent hyperflash or you can use an Electronic LED Flasher from: http://www.superbrightleds.com/cgi-b...rake-turn.html
Hope that helps.
Hope that helps.
Also white LED's put much LESS light through the colored lenses as opposed to LED's matching the lens color.
Brighter light is from normal incandescent 1157 bulbs:
as for the cluster: this should be very helpful
https://honda-tech.com/forums/acura-integra-6/diy-purchasing-leds-integra-gauge-cluster-uber-detailed-diy-1942094/
Also if your interested in changing the rpm and spedometer needle colors from orange to clear CAREFULLY remove the plastic cap in the middle and take some tissue paper and put it behind the needles so you dont get anything on the guages and use fingernail polish with no acetone and qtips and/or tissue paper to remove the orange paint that way when your led lights are on the needles will show the same led color instead of ugly orange
yeah you are right cuz when a changed them all i didn't notice that but i installed a rear fog light like a month ago but LED wouldn't light up as much as the OEM, the reason might be that the OEMs light up all around and the LEDs just light up to where theyre facing (forward). i agree with you
but i do see a big difference with my reverse and signals lights i have clear corner lights but the really look amber at night and yes they are visible at day.
Yep you're correct with that diagram. I even tried some 1157 LED replacements that had smaller LED's below the main ones pointing all around, but they still didn't light up nearly as bright as regular bulbs.
EusebioSam19
03-04-2010 09:13 PM
