Clicking coming from underdash when trying to start
Old 12-30-2010, 01:17 PM
4doorpowa's Avatar
Default Clicking coming from underdash when trying to start
ive tried a few things so far i tried the 4 prong relay i guess its a pwer acc relay, and ive put a paper clip in my clutch sensor at first i would trun it a few times it would finnaly start but today i get dash light but it wont start and i hear the fuel pump kicking on,any other suggestions?
Old 12-30-2010, 01:41 PM
4dregDC's Avatar
Default Re: Clicking coming from underdash when trying to start
Did u do a swap if so u should check your grounds
Old 12-30-2010, 01:49 PM
4doorpowa's Avatar
yea i just put the motor in i guess ill mess with the ground tomarrow i dont understand why i hear a clicking noise under the dash when i tried to start it, and now it dont even click. Yesterday i heard it click then it turned over i drove yesterday fine then today i went to start it it worked but my car stalled cause it so cold then it wouldnt turn over again..
Old 12-30-2010, 03:34 PM
Project H's Avatar
Mine did that when my battery died
Old 12-30-2010, 03:48 PM
civic-8442-'s Avatar
the clicking you hear is the main relay
Old 12-30-2010, 09:16 PM
4doorpowa's Avatar
no its not a relay, i just went out there and hit the lever to move the steering wheel up and down, and after banging it up and down a few times it fires up. Its got to be in the ignition im guessing
Old 12-31-2010, 11:52 AM
4doorpowa's Avatar
sounds like it was coming from the driver side fuse panel.
Old 12-31-2010, 12:03 PM
The Grumpiest
grumblemarc's Avatar
Sounds like the main relay to me.
Old 12-31-2010, 01:48 PM
4doorpowa's Avatar
main relay is on the passanger side correct?
Old 12-31-2010, 01:54 PM
MonkeyMagic's Avatar
the sound is the main relay clickin off and on
but it's probably being switched by a bad ignition switch.
reading comprehension people.
Old 12-31-2010, 02:02 PM
The Grumpiest
Maybe try a better thread title next time because the OP originally only complained about a clicking noise from under the dash.
Old 12-31-2010, 02:11 PM
lol, that'd definitely help the cause.
if being vague or confusing got results, nothing could touch most new members on h-t.
Old 12-31-2010, 02:12 PM
Old 12-31-2010, 08:43 PM
4doorpowa's Avatar
how about if you dont like what i wirte keep your comments to urself, i had got in a accendent with my other shell, had to swap everything into another car and did it within a day, and costed my 300 dollars when ur running 11s or better then talk it up otherwise shut the **** up. Happy new year!!
Old 12-31-2010, 10:31 PM
Carpe diem!
Sa.L.aS's Avatar
lol You can get 4 cylinder **** box into the 11's yet you cant figure out the "clicking noise near your fuse panel" is your main relay?
Old 01-01-2011, 04:37 AM
4doorpowa's Avatar
ahahahha if i hear about this main relay one more time im going to shoot myself, Do u guys not no how to read??? I said it was cooming from the driver side I GOT A 97 the main relay is on the passanger side, and i i also stated that ,it was cooming from the fuse box. there is one relay under the DRIVER side dash and its the power acc relay and its not the issure here
Old 01-01-2011, 04:43 AM
4doorpowa's Avatar
I think this guy is the closest, he just dont keep saying Main relay, im going to get a ignition switch today
Old 01-01-2011, 05:00 AM
The Grumpiest
True this! If you know everything why are YOU the one that can't get your car fixed? Next time give all the pertinent information up front and not AFTER people start giving you answers you don't like.
Old 01-01-2011, 05:16 AM
4doorpowa's Avatar
oh i love the **** talk
Old 01-01-2011, 07:13 AM
4doorpowa's Avatar
thx monkey it was the ign switch
Old 01-06-2011, 11:22 PM
xGBLOCKx13x's Avatar
maybe i should try that ouy cause my car dont even want 2 start
Old 01-07-2011, 12:32 AM
Stancetard Hate Monger
eghatch9295's Avatar
/\ yeah... throwing random parts at a problem is MUCH better than diagnosis....
Old 11-28-2013, 04:44 PM
Vtec_Hustlr's Avatar
I don't know about you guys but I have similar problems and solved it by replacing the starter. It had a clicking noise when I try to crank. My fuse n battery were fine..I doubt it's the relay. I don't know if it'll solve everyone's problem but wouldn't hurt to try it. Before I replaced it, my car started acting up and I got stuck. Came back the next day n it work. Drove it somewhere else and it wouldn't start ever again. Replaced the starter n it's running fine now
Old 01-23-2023, 09:30 PM
qwane609's Avatar
Old 01-24-2023, 04:36 PM
tamboo's Avatar
usually no need for a whole new starter just the solenoid rebuild kit is enough to bring it back from the dead:
https://www.ebay.com/itm/17166739076...Bk9SR5je_ei8YQ
lolv8s
07-07-2013 09:55 AM
ttcheung97
09-11-2009 05:00 PM
sjbmx
05-30-2008 06:27 PM
Nocturnal
12
08-11-2006 12:45 AM
DIYMIKE
01-30-2005 09:39 AM
Quick Reply: Clicking coming from underdash when trying to start
