Best camber kit for 94 accord
Old 12-28-2010, 11:20 AM
Blue94Accord's Avatar
Default Best camber kit for 94 accord
Just wondering what your guys opinions are on camber kits for a 94 accord. I have the ebay camber kit and it sucks. It comes lose every time i hit a bump.
Looking for something that wont suck.
Old 12-28-2010, 12:47 PM
He knows where you live!
TheMuffinMan's Avatar
Default Re: Best camber kit for 94 accord
Front or rear?
You really do not need one unless you want it for looks. Just have your toe 0'd when you get an alignment.
Old 12-28-2010, 12:50 PM
Balwin's Avatar
An EF Civic UCA fits on the CD Accord. Skunk2 makes a nice one for the EF Civic.
http://cgi.ebay.com/ebaymotors/SKUNK...Q5fAccessories
Old 12-28-2010, 12:58 PM
I need one for the front. The read camber kit is good. I'm just trying to get a even tire wear.
Your sure its the same?
Old 12-28-2010, 01:08 PM
Balwin's Avatar
Originally Posted by CD7_Accord-SiR
Yes! as some of you already know it can be done, 88-91 civic UCA will fit the CD/CF chassis...
thankz to antbo for sharing the info and being the first one who did it on the 5th gen
Skunk2 makes UCA for the EF so i picked up a set and installed them on my cd7 :cool:
on to the pics
this is a stock cd uca next to the ef skunk2 uca...
you wont need this middle piece....
Installed on the car.. This is a staight forward installation, no mods needed...
i did noticed the car got a bit lower :eek:
The car still needs an alignment, so that would probably happen on saturday, im going to post up the specs for ya'll
Old 01-09-2011, 05:19 PM
so this would fit too right?
http://cgi.ebay.com/ebaymotors/HONDA...ht_4217wt_1264
Old 01-10-2011, 01:53 AM
Balwin's Avatar
yeah but some people have tried it and dont like it.
Old 01-10-2011, 07:28 AM
what don't they like?
Old 01-10-2011, 09:23 AM
be professional
Targa250R's Avatar
Forget the adjustable camber kits and use the stock upper control arms or an equivalent replacement and have the toe set to dead center of the factory tolerance range. You won't have enough uneven tire wear to matter if the toe alignment is done correctly. If some lazy grease monkey is just setting it "within spec," then it won't be good enough and you'll shred the inside shoulders, but this applies both with and without significant negative camber.
I question whether that SH3 upper control arm has enough adjustment range to match the SV4 control arm. I'm curious to see the alignment print-outs from that one...
Old 01-10-2011, 09:55 AM
I don't get it, if its that easy to just have the toe at 0 then why does everyone say you need a camber kit?
I remember seeing my toe being around .04
Would having it set to .00 be that much of a difference?
Old 01-10-2011, 11:59 AM
Balwin's Avatar
It changes when you lower the car. Thats why I said get an alignment.
They didnt like the no name brand EF UCA because its typical ebay quality.
Old 01-10-2011, 12:26 PM
Ive gotten 3 alignments in the past 6 months. Every time the camber kit comes loose
Old 01-10-2011, 03:23 PM
Ok, so either:
1) You have a shitty camber kit
2) You didn't torque it correctly
3) You didn't use and loctite (or similar) thread goop
Ditch the camber kit if you have issues with it and just have the toe 0'd out. Use the washer trick in the rear if you have to. I had an Ingalls anchor joint kit and had 0 issues for the front for over a year.
Old 01-12-2011, 01:39 AM
SuShiBoiiii's Avatar
lol come on balwin why you posting that up if he wants regular tire wear. if your going to get a decent kit ingalls or wicked tuning
Old 01-12-2011, 02:20 AM
Balwin's Avatar
Lol I suggested that too... :salook:
Old 01-12-2011, 02:47 AM
be professional
Targa250R's Avatar
Because they're clueless.
You don't need camber adjusters to have even tire wear. You do, however, need a toe alignment that has been done correctly. Keyword: correctly.
I've driven around in my lowered cars for years without camber adjusters and have never had wear uneven enough to affect the service life of the tires (i.e. not more than 2/32" tread difference between the inside shoulder and the outside shoulder). I operated a Hunter optical alignment rack and specialized in performance, competition, and street alignments for several years, and currently do my own alignments with trig, toe plates, and a string box on a flat concrete pad. Unlike most alignment monkeys, I actually know what I'm doing.
Guessing won't get you close enough. If you really want help, you'll need to post your before and after print-outs from the alignment machine including all specs and tolerance range figures. If you don't have print-outs, then that's your first mistake - you should never have an alignment done without asking for both print-outs beforehand.
Old 02-21-2014, 07:50 PM
The Illest CD5's Avatar
What is the best way to extract the gold plate on the camber kit im having issues
Old 06-15-2016, 09:16 AM
shahriar35's Avatar
Anyone ever find the best way to extract the gold plate? Does it have to be taken off?
Old 11-21-2020, 11:01 AM
Derek Perez's Avatar
maybe your not worried about hp... on the dyno camber matters trust me I just had a low number tune thanks to camber, toe, and a bent wheel... according to my dyno tuner zero camber is more power to the street...
Old 11-21-2020, 12:14 PM
99stockcivic's Avatar
The amount of horsepower loss to the ground would be very small unless you are talking extremes. Plus the tire and all the rest matters just as much. Finally, what matters is the intention behind the alignment. A zero camber would produce the most tire wear, but would trade off for horsepower loss in the turns. So, for someone to say that is missing a piece of the whole picture. Often you want at least a touch of camber less skittishness. I would be very surprised to see a true horsepower loss or gain with small normal camber dialed-in. If in doubt, I'd listen to Targa250R as he certainly sounds like he has the most experience. I've had cases in some cars where I needed a camber kit, but in others I've not needed it.
Flipmonkey
Suspension & Brakes
01-08-2014 05:39 AM
Awake64
03-09-2011 07:44 PM
jdmhondacrx
Suspension & Brakes
03-06-2008 11:06 PM
Quick Reply: Best camber kit for 94 accord
