Old 12-26-2010, 12:01 AM   #1
hugens26
hugens26's Avatar
Default 97 Civic - How to properly bleed the clutch fluid?
Hey guys i need help i tried bleeding my clutch fluid out but i am having a problem doing it and my pedal is all the way to the floor can someone explain the process of how to do it by yourself. Thanks in advance.
hugens26 is offline   Reply With Quote
Old 12-26-2010, 04:47 AM   #2
grumblemarc
The Grumpiest
1996 Honda Civic
grumblemarc's Avatar
iTrader Rating: (4)
Send a message via AIM to grumblemarc Send a message via Yahoo to grumblemarc Send a message via Skype™ to grumblemarc
Default Re: 1997 Honda Civic (How to properly bleed the clutch fluid)
Get a neighbor to pump the pedal while you bleed it. Takes all of 5 minutes. But if you have no neighbors get one of those one-man bleeder kits from the auto parts store.
http://www.honda-tech.com/showthread.php?t=2539325
FAQs!--How to Turbocharge your Civic--Want a faster Civic?--DIYs
Originally Posted by wantboost View Post
I wish more parents would beat their children, then maybe most of them wouldn't be total spoiled, self absorbed *********.
grumblemarc is offline   Reply With Quote
Old 12-26-2010, 05:49 AM   #3
D Griff
D Griff's Avatar
Loosen the little nipple thing at the slave cylinder. Hook a hose onto it and run the hose into a jar of brake/"clutch" fluid. Have someone pump the clutch pedal.
D Griff is offline   Reply With Quote
Old 12-26-2010, 07:40 AM   #4
RonJ@HT
Raising the bar
2000 Honda Civic
My Garage
RonJ@HT's Avatar
^I use this too - only costs about $4.
Don't guess, troubleshoot.
Old 12-19-2012, 10:08 PM   #5
Medi-kal
Hello, all.
My name is Chris and I live in Chicago.
First off, I want to thank you for the info this site has! It's great and it seems to have a great community.
Secondly, I want to apologize for reviving an old thread.
Now that that's out of the way, onto business!
The directions say, "Make sure there is an adequate supply of brake fluid at the master cylinder, then slowly pump the clutch pedal until no more bubbles appear at the bleeder hose."
Is it possible for there to be air bubbles trapped in the master cylinder? If there is, can i still bleed from the bleeder screw from the slave cylinder?
I own a '93 Honda Del Sol and this is the first real problem I've had with the car since i bought it 2 years ago.
At first i thought that the clutch was sticking due to 'cold weather'. When it finally just stopped working, i looked and saw that there was no more brake fluid in the clutch reservoir (or whatever it's called). I'm not sure if it's due to a leak or not. I filled it up, but the clutch pedal is still to the floor. I'm think there's air in the line somewhere, and bleeding it may help get it working again.
Thanks in advance.
-Medi-kal
Medi-kal is offline   Reply With Quote
Old 12-20-2012, 01:23 AM   #6
HondaPartsHero
Technical Hero
HondaPartsHero's Avatar
Default Re: 97 Civic - How to properly bleed the clutch fluid?
If its empty you have a leak. Either at the master cylinder or slave cylinder or an associated line.
OBD1/2 SOHC/DOHC VTEC HARNESS
MINI ME SUBHARNESS
02 EXTENSION HARNESS
Hondapartshero.net
HondaPartsHero is offline   Reply With Quote
Old 12-22-2012, 03:51 AM   #7
Medi-kal
Thanks for the quick reply.
I've searched the forums trying to find a how-to guide on changing the master/slave
clutch cylinder but didn't have any luck.
(Either I'm not searching right, or there isn't one.)
Can someone point me in the right direction?
Thank you.
Old 12-22-2012, 04:15 AM   #8
grumblemarc
The Grumpiest
1996 Honda Civic
iTrader Rating: (4)
Have you actually looked at them? They bolt on/off.
Old 12-23-2012, 01:48 PM   #9
Medi-kal
Sorry for the delayed response. Christmas time has been busy, and it's
been pretty cold in Chicago.
I finally got the car in the garage and took a look at the problem.
There's a leak just behind the clutch pedal -which I'm guessing is
the backside of the clutch master cylinder.
I saw a how-to video for a nissan truck which gave me a general idea
of what i would need to do.
Any suggestions would be helpful.
Thanks in advance.
00, 1997, 96, accord, add, bleed, bleeding, civic, clutch, dx, fluid, flush, honda, properly, replacing, tech
Similar Threads
How to change clutch master cylinder fluid? ramboPandA Acura Integra 1 07-08-2014 09:37 PM
bleeding clutch mattbatson Honda Civic (2006 - Current) 2 04-14-2013 04:54 AM
Help quick: how to bleed clutch masetr cylinder hitop Acura Integra 17 03-07-2013 08:55 PM
ball-park how long to bleed clutch (there's no air, just freshening fluid) dazebreak Honda Civic/Del Sol (1992 - 2000) 7 02-03-2013 10:09 PM
1983 honda nighthawk Hex313 Honda Motorcycles 3 11-23-2012 09:10 AM
