B20B BOGGING DOWN. I NEED HELP!
Old 12-21-2010, 02:58 PM
2000EK9TYPER's Avatar
Default B20B BOGGING DOWN. I NEED HELP!
I HAVE A 98 B20B ON A 2000 EK AND THE PROBLEM I HAVE IS THAT IT BOGGS DOWN ON ME. WHEN I RUN IT IT DOESNT PULL. I SCANED THE CODES AND THE CODES I HAVE ARE: P0113 (IAT SENSOR 1 CIRCUIT HIGHT INPUT), P1509(MANUFACTURE CONTROL SPEED. IDLE SPEED CONTROL AUXILIARY INPUT), P0135(#2 SENSOR HEATER CIRCUIT MALFUNCTION), P1337(MANUFACTURER CONTROL IGNITION SYSTEM OR MISFIRE), AND P0141(BANK 1 SENSOR #2 MALFUNCTION HEATER CIRCUIT). I CHECKED THE TIMING AND ITS GOOD. I BELIEVE I EITHER HAVE TO CHANGE SPARKPLUG WIRE, CHECK FOR VACUUM LEAK OR REPLACE MAPSENSOR. CAN ANYBODY HELP ME FIX THIS PROBLEM?
Old 12-21-2010, 04:30 PM
MonkeyMagic's Avatar
Default Re: B20B BOGGING DOWN. I NEED HELP!
i'd bet anything the iacv and iat plugs are switched up.
might as well check to see if the map and tps plugs are switched. common problem with people doing swaps.
ChangT
04-28-2010 07:43 PM
jordan_civic
05-30-2008 10:35 PM
SUPERSONICGSR99
10-01-2004 04:03 AM
AcCoRdStReEtRaCeR
01-31-2003 09:23 PM
DuNkiN
08-08-2001 08:21 AM
Quick Reply: B20B BOGGING DOWN. I NEED HELP!
