Go Back   Honda-Tech > Honda and Acura Technical Forums > Forced Induction
Old 12-16-2010, 05:57 PM   #1
gs-r94coupe
Default what arp head studs do i use for my ls vtec
old setup was ls turbo with arp head studs and rod bolts,was wondering if i can use the head studs off my ls for the ls vtec.
im putting a 96 gsr head on it will the ls arp head studs work or will i need to buy different ones.
help please
gs-r94coupe is offline   Reply With Quote
Old 12-16-2010, 09:27 PM   #2
ryguy2588
ryguy2588's Avatar
iTrader Rating: (5)
Default Re: what arp head studs do i use for my ls vtec
"A B16 block will always use B16 headstuds no matter what B-series VTEC head because of the blocks deck. A GSR, LS/VTEC, B20/VTEC will use GSR headstuds no matter what B-series VTEC head."
The B16 head studs will work, but they just won't stick up as far as the GSR ones cuz the GSR ones are a little longer.
ryguy2588 is offline   Reply With Quote
Old 12-16-2010, 09:30 PM   #3
gs-r94coupe
so i cant use my ls ones i already have, i have to go buy gsr ones
Old 12-16-2010, 09:39 PM   #4
ryguy2588
ryguy2588's Avatar
iTrader Rating: (5)
No you can't use the LS ones. You have to use the VTEC head studs. Either the GSR or B16. I would just get the GSR ones because they're longer than the B16 ones.
Old 12-16-2010, 11:22 PM   #5
king06
king06's Avatar
GSR's
"i normally wouldnt post in GDD because you're all ferrari/bugatti/whale ***** interior driving *****.. "
king06 is offline   Reply With Quote
Old 12-16-2010, 11:40 PM   #6
AllShowNoGo727
iTrader Rating: (1)
v8killerb18
ARP LS VTEC head studs they are cheap...
Phearable.net Tuning FTW! Race-Spec Trusted and Proven Motorsport Wiring
AllShowNoGo727 is offline   Reply With Quote
Old 12-17-2010, 09:26 PM   #7
gs-r94coupe
aight thanks guys will go buy a set of gsr ones tomorrow lol
Old 01-01-2011, 06:29 PM   #8
Bseriescivic5
Bseriescivic5's Avatar
Send a message via AIM to Bseriescivic5
Is the deck height on the ls (b18a,b,) the same as gsr deck height? p72.???
http://www.backmotorsports.com
Bseriescivic5 is offline   Reply With Quote
Old 01-01-2011, 07:55 PM   #9
ryguy2588
ryguy2588's Avatar
iTrader Rating: (5)
No they aren't the same here are a couple sites that you can find more info and numbers for them.
http://www.honda-tech.com/showthread.php?t=1312642
http://www.zealautowerks.com/bseries.html
B18A/B: 211.84mm
B18C: 212.39mm
I'm pretty sure there can me a little variance in these numbers, but I don't believe there are the same.
arp, b16, b20, block, bolts, fit, gsr, head, headstuds, ls, lsvtec, series, studs, swap, vtec
