what fuel pump and fuel injectors ?
Old 12-30-2010, 04:41 PM
  #26
#1 Super Guy
94eg!'s Avatar
Default Re: what fuel pump and fuel injectors ?
Originally Posted by 00Red_SiR
check out post #7 above.
In that post you kinda go both ways. First you say cars can make over 200whp on 79lph pumps. Then you say you usually recommend 190lph walbro units...
Maybe I shoiuld just get a used GSR pump and call it a day...
Old 12-30-2010, 05:24 PM
  #27
All Motor Mentor
00Red_SiR's Avatar
If you read the whole thread up to that post, you'll see I'm not going two different ways at all. My post was addressing two things, first, that a stock pump can handle most performance builds out there and doesn't need to be upgraded. Second, if the OP really insists on buying a high volume fuel pump, then 190lph would be my choice over the 255Lph and I stated why.
Old 12-30-2010, 05:58 PM
  #28
#1 Super Guy
94eg!'s Avatar
Gotcha...
Guess I'll keep it stock. Thanks for the help!
Old 03-27-2012, 07:22 PM
  #29
zawn's Avatar
This post really helps
-Z-
As an example, someone put down 203/156(stock EX Pump 79lph, 310cc)
and 214/153 (Stock Dx Pump 79lph, 310cc)
Fact: Liters to Cubic Centimeters: 1 L = 1000cc's
Example 79 lph pump = 79,000 cc's per hour
So, 79,000 cc's per hour divided by 60 minutes = 79,000/60 = 1316.66 cc's min
So, 1316.66 cc's min/4 injectors = 1316.66/4 = 329.16 cc's min
Which is plenty large enough to support a 310cc/min injector.
In turn that would indicate that an upgrade to the 135lph would be all that is needed in most cases for a healthy buffer of fuel volume.
Example: 135lph x 1000 = 135,000 cc's/hour
135,000/60(minutes in the hour) = 2250cc's/min
2250/4 injectors = 562.5 cc's/min (Would support 560cc 's per injector)
Basically for all intents and purposes I will only refer to the majority of modified Hondas/Acuras.
Fuel Pump Ratings are as follows:
1988-2000 Civic CX, DX, EX = 79 lph
1989-2001 Integra RS, GS, LS = 79 lph
1999-2000 Civic SI = 135 lph
1994-2001 Integra GSR = 135 lph
1997-2001 ITR = 135 lph
I have seen a few problems with all motor cars trying to turn down the fuel pressure when using a 255L pump and not getting it to where they need. I would also recomend the 190LPH pump.
Old 03-28-2012, 11:53 AM
  #30
Deatschwerks's Avatar
1000/60 = 16.667
That'll help you skip a step.
Example > 320LPH * 16.667 = 5333.44 cc/min
Old 03-28-2012, 01:00 PM
  #31
frostwhite_92's Avatar
Stock fuel pump is fine.
Go with RDX injectors, run them at 60 psi and control them with Hondata. The RDXs offer a better spray pattern, will support the biggest of NA builds, and have OEM reliability.
Old 04-14-2012, 04:54 PM
  #32
jeffb20vtecc's Avatar
Go with 255
Old 04-15-2012, 10:37 AM
  #33
CheLude NY's Avatar
What fuel pump would u guys recomend for a Turbo app?? I'm shooting for 4-500whp and 1000cc injectors?
Old 04-16-2012, 06:46 AM
  #34
Depends on the fuel used.
500whp on gasoline > 255LPH DW200
500whp on E85 > 320LPH DW300
Old 04-16-2012, 07:09 AM
  #35
CheLude NY's Avatar
It's gonna be my dd, on 93 octane
Old 04-16-2012, 08:08 AM
  #36
The DW200 should be all you'd need, then.
...and since it is a DD, you'll like how quiet our pump is.
Old 04-18-2012, 03:42 PM
  #37
CheLude NY's Avatar
Jus out of curiosity, whats the max hp that is this safe to run w/ this pump??
Old 04-19-2012, 06:08 AM
  #38
Since we are in the All Motor forum, I'm assuming this is for a N/A build?
Gas or Ethanol? Base fuel pressure?
@ 40 psi, the DW200 flows 255LPH. That's enough to feed 1000cc injectors at 100% cycle and then some. 1000cc injectors will get you in the mid-600's on gas in a N/A application.
Old 04-19-2012, 07:38 AM
  #39
CheLude NY's Avatar
I apologize, i didn't see this was in all motor
vti444
12-07-2008 01:21 AM
deucedeuceEK
06-02-2007 04:33 AM
EG-B20vtec
11-17-2006 10:47 AM
jeremy.
09-29-2003 05:35 PM
Quick Reply: what fuel pump and fuel injectors ?
