Old 12-15-2010, 10:27 AM   #1
ferio252
ferio252's Avatar
Send a message via AIM to ferio252
Default Loud metal to metal sound on intial engine start in cold weather.
I have a D16Y7 automatic. Weather was a "cold for California" 45F or so. When I started, I heard what sounded like cylinders firing without oil. CLakaclakaclaka then went away. Honestly it was less then maybe a quarter of a second.
Does anyone else experience this in the morning after the car sits overnight? And a noob question, but when you put the engine into ON from Accessory w/o starting the car, does any oil at all squirt onto the block to prep the engine for initial startup?
Engine background: some 207K miles and engine oil changed religiously every 3K and checked level every week.
>>Wekfest SJ 2013 video coverage << Like, Subscribe and comment!
>>Hanzai Noodles!<<
ferio252 is offline   Reply With Quote
Old 12-15-2010, 10:40 AM   #2
habib
habib's Avatar
Default Re: Loud metal to metal sound on intial engine start in cold weather.
No oil is moved until you crank the engine, the only thing primed when the key is turned to the "on" position is the fuel pump
habib is offline   Reply With Quote
Old 12-15-2010, 11:19 AM   #3
AutoXer
2004 Volkswagen R32
My Garage
AutoXer's Avatar
Pretty common in every Honda I've had experience with. It's a combo of typical 4cyl piston slap and the oil being a little sluggish when cold.
AutoXer is offline   Reply With Quote
Old 12-15-2010, 11:51 AM   #4
ferio252
ferio252's Avatar
^ Thanks. It just sucks to hear first thing in the morning.
>>Hanzai Noodles!<<
Old 12-15-2010, 12:08 PM   #5
8YourV8
8YourV8's Avatar
Send a message via AIM to 8YourV8
Damn, I wish 45F was considered cold here.
Stock B18C on 10 PSI putting down 300. Nothing crazy or fancy.
8YourV8 is offline   Reply With Quote
Old 12-15-2010, 12:18 PM   #6
Kmiller
It could also be the starter grinding on the flywheel, mine did that today. Just throwing that out there, if you can narrow it down to that?
Kmiller is offline   Reply With Quote
Old 12-15-2010, 12:29 PM   #7
8YourV8
8YourV8's Avatar
I'd put my money on cylinder slap. Not really a huge issue; most Hondas do it. My Civic GSR and my Corolla both do it when it's under like 40 degrees out on the first start of the day. It's not like it's a continuous knock. If it were, then it would warrant a concern.
accord, car, cold, engine, engines, generally, honda, loud, louder, metal, sound, start, starting, suddenly, temp, weather
