Go Back   Honda-Tech > Honda and Acura Technical Forums > Forced Induction
Old 12-08-2010, 09:20 AM   #1
turboman2.2
turboman2.2's Avatar
Default spooling a t72 turbo?
I am thinking of buying this turbo from a friend. I have a 1.9 l ls vtec, 8.5.1 compression. Reving up to 9200 rpm. How fast would i be able to spool this turbo. Here are the specs.
Wet float bearing,
Turbine P Trim .96 A/R Turbine
Compressor Wheel 102.4mm/72.1mm
Turbine Wheel 74.1mm/64.6mm
Hot Side 3" V-band
Shooting for 26 psi of boost.
turboman2.2 is offline   Reply With Quote
Old 12-08-2010, 12:09 PM   #2
Mattb16teg
1993 Acura Integra
Mattb16teg's Avatar
Send a message via AIM to Mattb16teg
Default Re: spooling a t72 turbo?
Wet float bearing,
Hot Side 3" V-band
8.5! It's a HONDA!
Why so low!??
This is 2010, high cmp is perfectly fine on properly tuned turbo setups!
Your question all depends on the other specs of the motor such as cams and intake setup. The tune also factors a large amount into spool time.
"shooting for 26 psi of boost" is also relative and essentially means nothing! Forget all about how much PSI you want to run!!!!
93 Electron Blue DA
05 Carbon Gray TSX
Mattb16teg is offline   Reply With Quote
Old 12-09-2010, 10:24 AM   #3
turboman2.2
I know I should've got some higher comp pistons. My cams are stock b16, with b16 intake manifold, super tech valve springs and retainers, adjustable cam gears, gsr transmission with lsd and carbon syncros. It is running on e85.
Old 12-09-2010, 11:04 AM   #4
TheShodan
TheShodan's Avatar
iTrader Rating: (6)
Send a message via AIM to TheShodan Send a message via Yahoo to TheShodan
It'll "spool" tomorrow. Maybe the day after that.
“Don't let the opinions of the average man sway you. Dream, and he thinks you're crazy. Succeed, and he thinks you're lucky. Acquire wealth, and he thinks you're greedy. Pay no attention. He simply doesn't understand.” -Robert G. Allen
TheShodan is offline   Reply With Quote
72, 851, comp, h22, honda, mm, scroll, size, specs, spools, t72, tech, turbo, twin, wheel
