Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda Ruckus and Scooters
Old 12-05-2010, 06:33 PM   #1
Stenzo
Icon6 Ruckus troubleshooting help
My ruckus won't stay running. The idle speed varies and then it stalls.
I have checked the fuel and air filters, valve clearances, put in a new spark plug, checked the carb mount for cracks and tight clamps, checked the connectors on the wires on the carb for cleanliness and contact.
Any suggestions on how to further troubleshoot to find the cause??
Thanks.
Stenzo is offline   Reply With Quote
Old 12-05-2010, 07:38 PM   #2
EJ8CIVIC
EJ8CIVIC's Avatar
Default Re: Ruckus troubleshooting help
i know when i went from stock air box to a filter direct onto the carb, i had this (possbly same issue).. so i had to miss with the idle thingy...btw there a some rubber vaccum hose that is towads the bottom of the carb to the air box...so wat i did was pluged it and then mess with the idle again and got it right...hope this makes since..hope i help u out
EJ8CIVIC is offline   Reply With Quote
Old 12-05-2010, 07:51 PM   #3
Stenzo
Thanks EJ8CIVIC. Do you mean the idle speed adjustment? I tried turning that up and it did raise the idle, but the speed still "hunted" a few times then went down and it stalled.
I didn't see any other carb adjustment screws.
I forgot to mention that I removed the air cleaner hose and used my finger as a choke and that kept it running longer.
Could it be an electric control?
Old 12-05-2010, 08:07 PM   #4
EJ8CIVIC
EJ8CIVIC's Avatar
no prob bob...
i think that hose is what im talkn bout..ill get u a pic tomorrow to help out..i wud say hook up that hose and plug it wit a screw and mess with the idle again..jus idea
btw if ur now signed up on here this is a grrrreat place and lots of friendly ruckster on there
www.totalruckus.com
Old 12-09-2010, 08:09 AM   #5
STR8 H8N
STR8 H8N's Avatar
Thanks.
WHAT MODS DO YOU HAVE DONE? YOU MIGHT NEED NEW JETS SON
STR8 H8N is offline   Reply With Quote
2003, adjust, air, box, carb, honda, idle, ruckus, shooting, support, tech, touble, trouble, troubleshoot, troubleshooting
