Go Back   Honda-Tech > Community Forums > General Discussion and Debate
Old 11-29-2010, 08:10 PM   #1
builthatch
MiG-21 superfan
1975 MiG 21bis
builthatch's Avatar
Tony Mandarich Tony Mandarich Tony Mandarich Tony Mandarich Tony Mandarich
Send a message via ICQ to builthatch Send a message via AIM to builthatch Send a message via MSN to builthatch Send a message via Yahoo to builthatch Send a message via Skype™ to builthatch
Default garage parking assist
in my garage, i went from parking a mazdaspeed3 to a f'n double cab 4x4. i was thinking of lots of things to help park it precisely, but they would either be annoying or hard to do without access to tooling and a production plant in vietnam.
http://www.sears.com/shc/s/p_10153_1...u=03318181000P
i'm getting it. anyone have anything similar or use something other than a damned tennis ball on a string?
without getting something with lasers, i'm wondering what would be the best way to set something up where i could park it precisely in terms of not only the front of the truck, but also the side. the doodad above takes care of the front of the truck, but i'm still figuring out the side issue.
'09 Mercedes-Benz C63 AMG / '14 Audi Q5 3.0 S-Line / '07 Si sedan / END OF AN ERA / 5'16", 154.2 kgs / RON PAUL
builthatch is offline   Reply With Quote
Old 11-29-2010, 08:17 PM   #2
Rtzx9r
GDD 1%
2010 Acura TSX
My Garage
Rtzx9r's Avatar
Default Re: garage parking assist
put down a block of wood for distance in/out. Use your mirrors for the distance on the sides and back in. I back my S2K about 1 inch from my Ducati and have no issues (then again the S is tiny).
2010 TSX V6 Tech / 2004 S2K GPW & OEM Hardtop
2005 Element EX AWD / 1999 Ducati 996s #104/200
Rtzx9r is offline   Reply With Quote
Old 11-29-2010, 08:22 PM   #3
builthatch
MiG-21 superfan
1975 MiG 21bis
builthatch's Avatar
my truck has a backup camera and i'm not backing in! srsly tho, it is MUCH easier to pull in, considering my driveway, etc.
you mean a block of wood for the tires to hit? i was thinking that but these tires are HUGE - i can imagine it would push the wood a bit and before i know it i'd be too close. i need something that will put me within an inch of where i want to be, each and every time.
i definitely need the type of precision i had with my ms3. i was parking that thing with about a foot in front from the steps and a little less on the one side, leaving ample room for the rest of the garage to be used normally.
Old 11-29-2010, 08:32 PM   #4
__oversea
__oversea's Avatar
i have those small parking bump with double size tape. works okay till tape gets loose by turning tires with it.lol
I am going to try this, paint line on floor. (or Tape it) that way i can back in to garage straight and stop at the line. And you do need to stick out your head every time.
__oversea is offline   Reply With Quote
Old 11-29-2010, 08:38 PM   #5
Tim2179
eight equals equals equals D
1963 Buick Riviera
Tim2179's Avatar
iTrader Rating: (2)
Stumpjumper Pro
A block of wood will work. use a 4" x 4". You tires wont push it - they'll roll onto it. I also second backing in so you can use your mirrors better.
Save $25 when you sign up for Ting mobile: tingreferral.wordpress.com -- I get $25 too, so DO EET!
Tim2179 is offline   Reply With Quote
Old 11-29-2010, 08:41 PM   #6
seemorebuds
tennis ball and a string????
seemorebuds is offline   Reply With Quote
Old 11-29-2010, 08:43 PM   #7
builthatch
MiG-21 superfan
1975 MiG 21bis
builthatch's Avatar
yeah, that's old school. you basically park the car the way you want. then, you hang a tennis ball from a string, suspended from the ceiling so that it barely touches the windshield.
so, each time you pull in, when it hits the windshield, you know you've gone far enough and if you make it hit in the same spot, you'll have the side position dialed too.
Old 11-29-2010, 08:44 PM   #8
Tim2179
1963 Buick Riviera
Tim2179's Avatar
iTrader Rating: (2)
Stumpjumper Pro
10s.
Old 11-29-2010, 11:42 PM   #9
michael O
michael O's Avatar
Send a message via AIM to michael O
My dad uses a small tire chock. I'm sure you could find bigger ones or use a piece of wood like ppl are saying. I am not allowed to park in the garage when I'm home so I never have this problem.
88 Crx Dx
B16A-->B18a-->B16A-->B18a
michael O is offline   Reply With Quote
Old 11-29-2010, 11:50 PM   #10
SilentEdge
Batpool
SilentEdge's Avatar
I use a baby. Once it stops crying, I know I'm in a good spot.
ISK #A+
DEATH SQUAD
Originally Posted by George Knighton View Post
I hate you.
I pray that power be not in my words, but in truth that supersedes the mind of man, and our dead hope, and our blind faith in means that look to justify the ends.
SilentEdge is offline   Reply With Quote
Old 11-30-2010, 12:28 AM   #11
SDT Project EF
Send a message via AIM to SDT Project EF
use this method. works good. Sometimes you can just use other things in the garage as a marker.
SDT Project EF is offline   Reply With Quote
Old 11-30-2010, 03:58 AM   #12
sicky
grammer nawzi
sicky's Avatar
Depending on the floor in your garage, shoot a Hilti nail through the wood and then you don't have to worry about it moving.
sicky is offline   Reply With Quote
Old 11-30-2010, 04:33 AM   #13
Knightsport
You're a daisy if ya do
2009 Ford F-250
My Garage
Knightsport's Avatar
Knightsport
Learn how to drive you woman.
I'm your Huckleberry.
http://honda-tech.com/forumdisplay.php?f=11
Knightsport is offline   Reply With Quote
Old 11-30-2010, 04:58 AM   #14
Lugzilla
Canuckian
2001 Honda Prelude
My Garage
This, for realz.
Originally Posted by Abandoned Ship View Post
so many people, so many srs, too many lulz.
Lugzilla is offline   Reply With Quote
Old 11-30-2010, 05:45 AM   #15
-Gary-
-Gary-'s Avatar
Meh, it's new vehicle-itis. Totally understandable.
I had a bag of shot that I didn't use for hand loads that I used when we parked the Suburban in the garage.
-Gary- is offline   Reply With Quote
Old 11-30-2010, 06:46 AM   #16
alphalanos
2000 Honda S2000
alphalanos's Avatar
Send a message via AIM to alphalanos
what? I just pull up until see things in front of the car start moving. Done.
2000 Honda S2000
alphalanos is offline   Reply With Quote
Old 11-30-2010, 06:52 AM   #17
Ross
Ross's Avatar
Send a message via AIM to Ross
Awesome garage, btw!
2012 Crosstour EXL 4WD NAV | 2009 Si Sedan NAV
Ross is offline   Reply With Quote
Old 11-30-2010, 08:16 AM   #18
Knightsport
2009 Ford F-250
My Garage
Knightsport
I park a 3500 next to the Tahoe from time to time, quit making excuses for this nancy.
Old 11-30-2010, 10:08 AM   #19
shamoo
Will you make something up for me please?
2008 BMW M3
shamoo's Avatar
They make these "mats" that are yellow and have two little humps on it. You just drive until you feel your tire go over the first hump. It won't "slide" because the tire is already on the mat prior to going over the first hump. Will try to find a pic.
'12 Fit Sport w/navi | '08 E92 M3 (Sold) | '07 S2000 (Sold) | '01 S2000 (Stolen) | '97 Integra LS (Sold)
'12 Monster 796 ABS | '05 YZF-R6 (Sold)
shamoo is offline   Reply With Quote
Old 11-30-2010, 10:17 AM   #20
PatrickGSR94
1994 Acura Integra
PatrickGSR94's Avatar
iTrader Rating: (1)
Send a message via AIM to PatrickGSR94
We have the plastic floor thingy from Lowe's that sticks down, for both of our cars. Works great, although mine has come off the floor after about 3 1/2 years so I need to stick it back down.
One year I gave my parents a pair of ultrasonic parking sensors that has a green, yellow, red light on it. My mom still uses hers with her 07 Camry, but my dad can't use it because his Tacoma crew cab long bed literally has inches to spare in the garage.
So he did the ball on a string thing, and it works just fine. To be safe he also mounted a 2x8 on the wall with carpet over it, just to keep the truck bumper from impacting the sheetrock if he pulls in too far.
I mean there is literally 1/2" clear between the front bumper and the carpet on the 2x8, and about 1" between the rear bumper and the garage door when his windshield touches the ball on the string.
Please do not PM me with technical questions. Create a thread in the appropriate forum.
H-T OG member #8927 class of '02 ● Koni + GC InstallHID retrofit club
member #0001
PatrickGSR94 is offline   Reply With Quote
Old 11-30-2010, 10:29 AM   #21
builthatch
MiG-21 superfan
1975 MiG 21bis
builthatch's Avatar
welcome to my world.
Old 11-30-2010, 10:37 AM   #22
sixsixsix
OneWayHighway
sixsixsix's Avatar
sixsixsix sixsixsix sixsixsix sixsixsix sixsixsix
Send a message via ICQ to sixsixsix Send a message via AIM to sixsixsix Send a message via MSN to sixsixsix Send a message via Yahoo to sixsixsix Send a message via Skype™ to sixsixsix
I like this alternative. Do you have an experience with these mats?
click works
"music is like candy...only good once you get rid of the rappers"
sixsixsix is offline   Reply With Quote
Old 11-30-2010, 10:37 AM   #23
Knightsport
2009 Ford F-250
My Garage
Knightsport
You sissy.
Seriously, just use the ball and string method if you must. It's cheap and effective.
Old 11-30-2010, 10:59 AM   #24
PatrickGSR94
1994 Acura Integra
iTrader Rating: (1)
The little mat works great. Just make sure you get one with a small initial bump and a LARGE end bump. Otherwise if you don't hit the first one fast enough, you'll stop and you'll have to give it more gas to get over and likely go over the second one. It's always best to hit the first one with a slight bit of momentum.
member #0001
Old 11-30-2010, 11:22 AM   #25
typerlegend
typerlegend's Avatar
Really? You're doing it wrong...
typerlegend is offline   Reply With Quote
accord, assist, assistant, ball, bump, garage, honda, installation, mat, park, parking, reflective, sign, small, string, tennis, width
