HOW TO REMOVE BOLT FROM HARMONIC BALANCER PULLEY
I am attempting to replace the water pump on my grandson.s F22B2 2.2 L. engine. To remove it, I don't know whether to turn it counter-clockwise (which would be normal) or clockwise which would be unusual.
I need to help him, please help me. Which way do I turn it to loosen it, so I can remove cover to replace water pump.
Is there anything special I should know (do's or dont's) when replacing the water pump after I get the cover off the front of the engine?
Grandpa would really appreciate some help. Can't afford to take to shop.
Jim
Diana, Texas
Jim
Diana, Texas
Re: HOW TO REMOVE BOLT FROM HARMONIC BALANCER PULLEY
counterclockwise. You need to use an impact. You can use this http://www.denlorstools.com/home/dt1...and_acura.html to lock the harmonic balancer and use it to reapply the balancer with the proper torque specs
Thank you for the reply. I had purchased the tool you suggested and with your info I got the bolt out.
Thanks, again.
Jim
Diana, Texas
Thanks, again.
Jim
Diana, Texas
JUN.
05-12-2008 10:54 AM
