Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda CRX / EF Civic (1988-1991)
Old 11-21-2010, 12:20 PM   #1
EF9Infantry
1995 Honda Civic
Default changing a lower control arm bushing. need help
Anyone had problems changing one of these. I've lubed it and jammed the sh*t out of it and it still won't come out. Anyone have advice how else to get this bushing out.
EF9Infantry is offline   Reply With Quote
Old 11-21-2010, 12:45 PM   #2
Clipsed
Clipsed's Avatar
iTrader Rating: (2)
Send a message via AIM to Clipsed
Default Re: changing a lower control arm bushing. need help
you need a shop press to do it, good luck trying with a BFH.
4th Gen Sedan Enthusiast Group On FB!
My 4dr Build!My FS Thread!
Vouches:JDMKAY,Mashi2Choco,idh!,lunalink,KINGVEM^^ ED6
Clipsed is offline   Reply With Quote
Old 11-21-2010, 12:54 PM   #3
efjones9
efjones9's Avatar
Trai Jones low ef9
propane torch and have fun lol jk
I Old SkooL
efjones9 is offline   Reply With Quote
Old 11-21-2010, 12:59 PM   #4
fredrocs
i've used a BFH to knock them out and back in, but it's always been done on a lift. in this case any kind of lube is your enemy. if you're just tryna knock it out, i hope you're hitting it from the inside out and when you're installing them go from the outside in. what you really need is a tool like this http://www.denlorstools.com/home/dt1...ol_sp_651.html
hope this helps!
1994 honda civic si w/bar'd 1997 b18b
www.freeingupsomespace.tumblr.com
fredrocs is offline   Reply With Quote
Old 11-21-2010, 01:51 PM   #5
EF9Infantry
1995 Honda Civic
Thanks guys. Damn I thought I could just knock it out with a hammer. Wish I would have checked here before destroying it then asking how to do it. Lol oh well lessons learned.
Old 11-21-2010, 03:29 PM   #6
Tyson
Tyson's Avatar
yeah a press is needed to do it properly.
heating it and cutting it out is going to ruin the control arm. it will certainly burn off the surrounding paint and then require a repaint.
a balljoint press like the ones you can rent is hardly adequate enough either.
just use a proper press.
Don't IM me your TECHNICAL question. Start a thread, I'll answer there.
FS: Mugen CF-48 13x5.5 -38 Wheels *NIB*
FS: 4040 Brake Proportioning Valves
Tyson is offline   Reply With Quote
Old 11-21-2010, 08:40 PM   #7
hatchet_honda
hatchet_honda's Avatar
Send a message via AIM to hatchet_honda
rear lower control arm bushing? ive always just replaced both the arms with aftermarket ones that came with new urethane bushings already. PITA to replace on stock arms
hatchet_honda is offline   Reply With Quote
Old 11-21-2010, 09:33 PM   #8
fredrocs
ok backing up, are you trying to replace the front lower control arm bushings or the rear trailing arm bushings? the procedure is totally different for both.
2005, 94, accord, arm, bushing, bushings, change, changing, civic, civic2001, control, crv, front, honda, lower, replace
