Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Acura TL, RL & ZDX
Old 11-17-2010, 04:36 PM   #1
nortonmoto
Default 02 TL Type-s W/codes P0740 & P1740
My TL type-s is not drivable and transmission oil is burnt and nasty. My code are p0740 & p1740 I need help thanks!
nortonmoto is offline   Reply With Quote
Old 11-21-2010, 07:51 PM   #2
wc@acura
wc@acura's Avatar
Default Re: 02 TL Type-s W/codes P0740 & P1740
DTC P0740: Problem in Lock-up Control System
DTC P1740: Problem in 4th Clutch Pressure Switch Circuit
Get a new Tranny.
wc@acura is offline   Reply With Quote
Old 11-22-2010, 09:46 AM   #3
polishedturd
I like PIE
polishedturd's Avatar
sounds like the torque converter took a crap. very common for honda torque converters to fail and clog up the internal filter and then the rest of the tranny goes. you need a rebuild and a new converter.
polishedturd is offline   Reply With Quote
Old 12-12-2010, 09:10 PM   #4
wc@acura
wc@acura's Avatar
Yup//
02, 2002, 4th, acura, check, circuit, clutch, code, converter, engine, p0740, p1740, pressure, problem, switch, tl, torque, type
